November 2nd, 2015, 10:01
Hi
I'm Domenico from italy.
This is my first time here...
I have a SSD memory taken off from a microsoft surface pro (1514) that is fallen down and can't boot.
I bought a caddy to read the memory directly without luck.
Do you think that i could recovery data from it? I'm asking for a jtag method or a repair way...
Thank you
- Attachments
![20151102_145711[1].jpg (4.59 MiB) Viewed 10818 times 20151102_145711[1].jpg](./download/file.php?id=10930&t=1)
![20151102_145724[1].jpg (4.38 MiB) Viewed 10818 times 20151102_145724[1].jpg](./download/file.php?id=10929&t=1)
November 2nd, 2015, 10:09
Show model of controller - under the sticker.
November 2nd, 2015, 10:14
You might want to check a second adapter first. Those mSATA to SATA adapters can sometimes be touchy. Unless you have pro equipment to rebuild the data from the NANDS, I don't think you want to go there.
November 2nd, 2015, 10:15
here is the controller...
- Attachments
![20151102_151242[1].jpg (4.52 MiB) Viewed 10807 times 20151102_151242[1].jpg](./download/file.php?id=10931&t=1)
November 2nd, 2015, 10:22
i'm sure that adapter works.
What do you think about reflowing all the nand chips?
November 2nd, 2015, 10:52
very risky, 1 misaligned chip that creates a short and it is toast. but not sure if I have ever seen a chip off solution for marvell, I would be interested to see the dumps.
But if no other option, certainly worth a try. sometimes you can look sideways down between bga and pcb and see a broken ball, I see it regularly in flash drives looking under microscope
November 2nd, 2015, 11:27
Good news:
i have reflowed the controller side with 300 degrees air gun, pre-heat and many flux... it is working now!
thanks to all
November 2nd, 2015, 11:44
great job!, the result is a pay off for first checking for advice then proceeding in a careful and controlled manner. well done
