 Post subject: PNY 240 GB ERROR
PostPosted: November 6th, 2015, 8:22
Hello!! :mrgreen:
Please help me!
look log and print screen!
Thanks!!
CONFIGURATION GENERAL INFORMATION:
Device type......................................................... : SSD
Device interface.................................................... : SATA (SATA Rev 2.6)
Rotation Rate....................................................... : Non-rotating media
Main data
Model............................................................... : SandForce{200026BB}
Serial number....................................................... : 1
Firmware............................................................ : 402ABBR0
WWN................................................................. : 500232D000000001
Current Logical Parameters
Cylinders........................................................... : 0 0
Heads............................................................... : 16 16
Sectors............................................................. : 63 63
Capacity............................................................ : 0 MB
Capacity available in LBA Mode...................................... : 64 ,0 MB
Capacity available in LBA 48 Mode................................... : 64 ,0 MB
Capabilities
Standby timer values supported...................................... : [YES]
IORDY supported..................................................... : [YES]
IORDY disabled...................................................... : [YES]
LBA supported....................................................... : [YES]
DMA supported....................................................... : [YES]
PIO MODE
PIO MODE 3 Support.................................................. : [YES]
PIO MODE 4 Support.................................................. : [YES]
Available DMA Mode
Multiword DMA Mode 0................................................ : [YES]
Multiword DMA Mode 1................................................ : [YES]
Multiword DMA Mode 2................................................ : [YES]
Active UDMA/33 modes
Ultra DMA/33 Mode 0................................................. : [YES]
Ultra DMA/33 Mode 1................................................. : [YES]
Ultra DMA/33 Mode 2................................................. : [YES]
Ultra DMA/33 Mode 3................................................. : [YES]
Ultra DMA/33 Mode 4................................................. : [YES]
Ultra DMA/33 Mode 5................................................. : [YES] Selected
Ultra DMA/33 Mode 6................................................. : [YES]
Timing
Minimal multiword DMA cycle time.................................... : 120 ns
Recommended multiword DMA cycle time................................ : 120 ns
Minimal multiword PIO cycle time w/o stream control................. : 120 ns
Minimal multiword PIO cycle time with IORDY......................... : 120 ns
Supported standards
ATA - 3............................................................. : [NO]
ATA - 4............................................................. : [YES]
ATA - 5............................................................. : [YES]
ATA - 6............................................................. : [YES]
Security system
password set........................................................ : [NO]
HDD Locked.......................................................... : [NO]
HDD Frozen.......................................................... : [NO]
wrong password count exceeded....................................... : [NO]
security erase support.............................................. : [NO]
security level...................................................... : High
POWER MANAGEMENT
Mandatory power manement............................................ : [YES] Enabled
Power up standby.................................................... : [NO]
Advanced power manement............................................. : [NO]
Advanced power manement value....................................... : 65278
AUTOMATIC Acoustic Management
Feature set......................................................... : Not supported
Current value....................................................... : 0
Vendor recomended value............................................. : 0
Supported Command Sets
NOP................................................................. : Not supported
READ BUFFER......................................................... : Supported Enabled
WRITE BUFFER........................................................ : Supported Enabled
Host Protected Area feature set..................................... : Not supported
DEVICE RESET command................................................ : Not supported
SERVICE interrupt................................................... : Not supported
Release interrupt................................................... : Not supported
Look-ahead.......................................................... : Supported
Write cache......................................................... : Supported
PACKET Command feature set.......................................... : Not supported
Power Management feature set........................................ : Supported Enabled
Removable Media feature set......................................... : Not supported
Security Mode feature set........................................... : Not supported
SMART feature set................................................... : Not supported
FLUSH CACHE command................................................. : Supported Enabled
Device Configuration Overlay feature set............................ : Not supported
SET MAX security extension.......................................... : Supported
SET FEATURES subcommand required to spinup after power-up........... : [NO]
Power-Up In Standby feature set..................................... : Not supported
Removable Media Status Notification feature set..................... : Not supported
DOWNLOAD MICROCODE.................................................. : Supported Enabled
Device Sector Info
Multiple logical sectors per physical sector........................ : [YES]
Logical Sector Longer than 256 Words................................ : [NO]
Logical sectors per physical sector................................. : 8
Alignment of logical blocks within a larger physical block.......... : 0
Words per Logical Sector............................................ : 256 512 b
Нет ничего невозможного
 Post subject: Re: PNY 240 GB ERROR
PostPosted: November 6th, 2015, 8:49
http://forum.hddguru.com/viewtopic.php?f=10&t=31929#p221571
PostPosted: November 6th, 2015, 8:52
Dmitri wrote:
:mrgreen:
Is new case!!
PostPosted: November 6th, 2015, 10:11
Dmitri probably meant to say viewtopic.php?f=10&t=31929&p=221571#p221571
Dmitri wrote:
If this SSD is actually Sandforce-based, then problem is properly implemented strong encryption with long random key, which is lost due to controller failure.
Users browsing this forum: Ahmed Saeed and 140 guests
