 Post subject: MZRPC128HACD-000SO SSD LIF?
PostPosted: November 10th, 2015, 15:50
Just wanted to make sure this is drive failure and not operator error (ie me). Got the above drive in that looks like its a standard LIF connection. Cannot get this drive live PC-3000. Is it a standard LIF (see image). Its from a Sony VAIO SVZ1311AFXX.
 Post subject: Re: MZRPC128HACD-000SO SSD LIF?
PostPosted: November 10th, 2015, 16:36
That's two SATA drives in a RAID configuration. You just need to treat them as separate drives. If the SATA Tx/Rx pins are not obvious to you, there is a thread in this forum that explains how to make your own cables.
viewtopic.php?f=1&t=18418
Hopefully your "standard" LIF cable didn't apply power to the wrong pins, otherwise you may have killed both drives.
PostPosted: November 10th, 2015, 17:04
Thanks Fzabkar. Reading that post it looks like several people have made the same mistake.
Users browsing this forum: Majestic-12 [Bot] and 148 guests
