| First Attempt - Monolith Plastic Coating Removal http://forum.hddguru.com/viewtopic.php?f=10&t=32436 |
Page 1 of 1 |
| Author: | Amarbir[CDR-Labs] [ December 4th, 2015, 10:23 ] |
| Post subject: | First Attempt - Monolith Plastic Coating Removal |
Hello Everyone , Today i Tried 1 Monolith MMC Card .This is What i Got In The End .Can Some Seniors Tell Me If This Pinout Is Know ? . Its a Dead Card When Connected To Computer Using Kingston Card Reader . The Actual Card Photo [ Side A And Side B ] ![]() ![]() The Photo Of The Monolith After Coating Removal ![]() PS : Have a Few Questions Will Ask |
| Author: | HaQue [ December 4th, 2015, 10:54 ] |
| Post subject: | Re: First Attempt - Monolith Plastic Coating Removal |
IMHO, I would start with something a lot simpler. but this may help: http://www.hardwarebook.info/MMCplus |
| Author: | Amarbir[CDR-Labs] [ December 4th, 2015, 11:00 ] |
HaQue wrote: IMHO, I would start with something a lot simpler. but this may help: http://www.hardwarebook.info/MMCplus Ha haaa , Haque Sir Just Greasing My Hands With that Black Filthy Plastic |
| Author: | HaQue [ December 4th, 2015, 11:13 ] |
you don't need to get it all off. on normal monoliths, you would solder to parts such as circled. NOTE- these are not the right points, I don't have this pinout available, this is only an example. Attachment: 103bb81.jpg [ 32.98 KiB | Viewed 7879 times ] The only reason you would remove all coating, is for a catalog photo to ID like devices in the future. If you know the pinout, you only need remove coating to expose these solder points and that's all. we are not making beautiful art here, we are recovering DATA!! these may lead you in the right direction: http://elm-chan.org/docs/mmc/mmc_e.html http://www.nxp.com/documents/application_note/AN10406.pdf http://www.retroleum.co.uk/electronics-articles/basic-mmc-card-access/ http://www.dejazzer.com/ee379/lecture_notes/lec12_sd_card.pdf |
| Author: | Amarbir[CDR-Labs] [ December 4th, 2015, 12:18 ] |
HaQue wrote: you don't need to get it all off. on normal monoliths, you would solder to parts such as circled. NOTE- these are not the right points, I don't have this pinout available, this is only an example. Attachment: 103bb81.jpg The only reason you would remove all coating, is for a catalog photo to ID like devices in the future. If you know the pinout, you only need remove coating to expose these solder points and that's all. we are not making beautiful art here, we are recovering DATA!! these may lead you in the right direction: http://elm-chan.org/docs/mmc/mmc_e.html http://www.nxp.com/documents/application_note/AN10406.pdf http://www.retroleum.co.uk/electronics-articles/basic-mmc-card-access/ http://www.dejazzer.com/ee379/lecture_notes/lec12_sd_card.pdf Sir , You Are Always Very Supportive ,Thanks From The Bottom Of My Heart .You Know i Am Heading To This Field Of Recovery And Its Tough a Hint Here and There Helps + All The Hard Work i will Pour In . |
