Help please, SSD locked by Insyde BIOS
Posted: December 28th, 2015, 9:53
Hi, i spent all day researching how to unlock my drive and ended up here.
My ssd was locked by bios. At first, i set both supervisor password and hdd password with the same password. Unfortunately, the system stated that my hdd password is incorrect when i try to log in. However, i am pretty sure that i typed the rufht password because i have to input the password twice in the set-up password process. But i have no idea how it went this way.
I try to crack the master password from the number given when i typed the wrong password three time ( like this http://youtu.be/V6X8pBg6BfQ). I craked the code using https://bios-pw.org, and the result looks good because the screen turned black (in black) after i put the generated master password, but it still not work.
So, then i searched more until i know that ( i assume) my ssd was at maximum security mode. Then, i tried to run some tools via hiren's bootCD 15.2, the frist tool is ATAPWD and the result showed "no ATA deives detected", then Victoria 3.3.3 and it stated that " Drive not say DRSC, DRSY or not remove BUSY....", and the last is MHDD that i just typed "ID" to see the information and the program stated "Drive is not ready."
Kindly help me find it out cause i don't know what to do since it appears that any program cannot access my ssd at all.
Thank you
Thank you
