1920 USB Flash
http://forum.hddguru.com/viewtopic.php?f=10&t=32834
Author:  einstein9 [ January 31st, 2016, 13:04 ]
Post subject:  1920 USB Flash
Someone brought me this damn flash which i have no idea FROM WHERE EXACTLY
the Image here will say it all.
Enjoy it. :wink:
Author:  pcimage [ January 31st, 2016, 14:07 ]
Post subject:  Re: 1920 USB Flash
Looks more like a software protection dongle than a USB flash to me.
Once we had a wireless mouse/keyboard dongle sent in to us for recovery! :-)
Author:  arvika [ January 31st, 2016, 14:23 ]
Yes, i confirm. It is used as protection key.
Author:  fzabkar [ January 31st, 2016, 15:57 ]
http://www.google.com/search?q=%22WIBU- ... letype:pdf
WIBU-KEY User’s Guide:
http://ftp.tuebingen.mpg.de/pub/kyb/ber ... e/test.pdf
Datasheet:
http://cdn.wibu.com/fileadmin/wibu/docu ... ystems.pdf
Author:  jermy [ January 31st, 2016, 21:13 ]
Have you been able to recover the data ? :lol: :lol: :lol:
Author:  einstein9 [ February 1st, 2016, 4:29 ]
I just wanted to have a DUMP of its contents
Client came to me wanted to have a Clone of it (not saying anything about it)
I took an image and posted it here.
Rule #1 in DR: Clients have a Master Degree in Lying
Author:  jermy [ February 1st, 2016, 5:43 ]
+1
Author:  DRUG [ February 26th, 2016, 22:39 ]
Yeah, many industrial hardware / software use this kind of dongles as a extra protection against piracy.
Would one be able to clone that, perhaps edit the serial number and make it work ? (i do believe those dongles authenticate with the software server.)
Author:  HaQue [ February 27th, 2016, 5:07 ]
not as easy to clone dongles as you think. some store part of the code of the app on the dongle, and you need it to run various enhancements, or the software itself. some are a decryption key to the exe after the stub has run, and some are pathetic excuses for protection... but if you like a good timewaster, then by all means play around with it ;-)
BTW depending on your country laws, it may be illegal to actually clone it.
Author:  digitalferret [ February 28th, 2016, 13:02 ]
"hey could you ̶p̶i̶r̶a̶t̶e̶ clone me a copy of this please?"
yeh, agreeing with others, he's trying to work a fast one on you there.
As per HaQue, dongles will have a combination key hard coded to protect against such folks.
Maybe ask the client if he has heard the word "complicit" used before, with relation to this sort of clone?
Keep it safe, keep it legal
Author:  jeremyb [ March 1st, 2016, 2:47 ]
Lol, I actually performed a successful data recovery on one of these.
My client had broken the USB connector off the dongle, somebody glued it back on, after a few re-gluing cycles they couldn't keep the connector on.
I ordered an identical dirt cheap dongle for another product off ebay, swapped the prom and saved the day. Plus it looked 100% stock.. lol
Author:  data-medics [ March 1st, 2016, 9:23 ]
I had an identical case a few months back too. What I did is look through all my cheap thumb drives and found one with the exact same shape/size PCB, soldered a new USB end on it, and put it into the new plastic case from the thumb drive. Customer felt like they were getting back a brand new dongle, it was even blue instead of the original red color.
