 Post subject: Pinout Needed
PostPosted: April 1st, 2016, 17:22
Anyone have a pinout for this?
Marking on the chip are KA02G1106.
 Post subject: Re: Pinout Needed
PostPosted: April 3rd, 2016, 6:56
Well,
The Plastic Remove Job Needs a Pat on Your Back Brother ,Job Well Done .What Tools Are you Having
PostPosted: April 4th, 2016, 12:57
Well,
Thanks Amarbir :D I use a mix of fine grit sandpaper (the wet/dry type also called emery paper) and a fiberglass pencil. The pencils are very good indeed for this type of job. Just wear gloves when you use them.
PostPosted: April 4th, 2016, 13:05
Well,
Well,
Commendable Work i Must Say again .Best of Luck With Recovery Of This Case ,Do Post If You Succeed
Users browsing this forum: Majestic-12 [Bot] and 93 guests
