HDD GURU FORUMS
http://forum.hddguru.com/
Pinout Needed
http://forum.hddguru.com/viewtopic.php?f=10&t=33199
Page 1 of 1
Author:  ddrecovery [ April 1st, 2016, 17:22 ]
Post subject:  Pinout Needed
Anyone have a pinout for this?
Marking on the chip are KA02G1106.
Author:  Amarbir[CDR-Labs] [ April 3rd, 2016, 6:56 ]
Post subject:  Re: Pinout Needed
Well,
The Plastic Remove Job Needs a Pat on Your Back Brother ,Job Well Done .What Tools Are you Having
Author:  ddrecovery [ April 4th, 2016, 12:57 ]
Well,
Thanks Amarbir :D I use a mix of fine grit sandpaper (the wet/dry type also called emery paper) and a fiberglass pencil. The pencils are very good indeed for this type of job. Just wear gloves when you use them.
Author:  Amarbir[CDR-Labs] [ April 4th, 2016, 13:05 ]
Well,
Well,
Commendable Work i Must Say again .Best of Luck With Recovery Of This Case ,Do Post If You Succeed
http://www.phpbb.com/
