 Post subject: OCZ ARC100 Indilinx IDX500M10-BC
PostPosted: March 25th, 2016, 21:01
Hi, I have an OCZ ARC100 480GB to recover. Imaging fine until it hits 33GB then imaging halts. Controller is Indilinx IDX500M10-BC and there are 16 Toshiba TH58TEG8DDKBA8C NAND chips.
Anyone know of any issue already discovered for the symptoms?
Or if chip off is similar to the earlier Indilinx Barefoot chips such as the IDX110M00 and IDX400N00?
I see mention of AES256 support, is this native encryption or user through a utility that may not be implemented?
any help would be great, thanks
 Post subject: Re: OCZ ARC100 Indilinx IDX500M10-BC
PostPosted: March 25th, 2016, 21:42
Nothing after that point, even in reverse?
PostPosted: March 25th, 2016, 22:02
Could we see the SMART report?
PostPosted: March 26th, 2016, 11:10
It hangs windows at that point. I don't have hardware tools for SATA DR.. But good point about reverse, using DMDE, it is at 154GB, no errors cloning in reverse. It detects and is accessible in windows, and I can access the file system fine until I touch certain files or folders. then windows hangs.
Of course the customer is mainly concerned oubt the 4.7GB .pst file. said pst copies merrily until 2.61GB then hangs. Of course, who would expect any different!
My guess is a bad nand chip or part of.
will see how far it gets going backwards... thanks for the idea.
Sure, here are 2, one from Crystal and the other the OCZ util:
Thanks guys
PostPosted: March 26th, 2016, 11:18
If you have use PC3K to clone the drive.
PostPosted: March 26th, 2016, 11:21
Thanks, but No I don't have it, I don't have any SATA DR tools, only flash.
I know PC3K has barefoot 3 tool and some solutions for various issues using technological mode.
I'm guessing it will reverse clone back to damaged chip and stop, and the pst file will be unrecoverable. not sure if PST files are only part copied if anything can be extracted from them.
PostPosted: March 26th, 2016, 15:14
Some time ago I helped a user recover data from an SSD with a similar problem. He played with the NAND supply voltage among other things. IIRC SMART reported some problems that pointed us in that direction.
Just out of curiosity I checked the numbers for attribute 0xAB.
User accessible capacity + Available OP Sector Count
    = (480.1 GB) + (152 734 032 x 512 bytes)
    = 519.96 GiB
    = 512GiB + 8GiB
    = (16 x 32GiB) + 8GiB
I would have thought that the sum should correspond to the total capacity of the NAND array but it appears that there is an additional 8GiB capacity (0.5 GiB per chip).
PostPosted: April 19th, 2016, 13:07
    = 519.96 GiB
    = 512GiB + 8GiB
yes this drive is overprovisioned.
having no luck any other way, I de-soldered the first BGA132 NAND and read it. Well 1/2 of it, I guess. connected to D0_0 - D7_0 and CE_0_0, RB0_0, CE1_0, RB1,0 for 2x 8GB banks. I am supposing when I wire the D0_1 - D7_1 I will get the other 2 banks.
problem is I cant see any data / SA structure in the dump. Read it DDR, and looks right (no double bytes)
I know the first barefoot had join by byte, second didn't. This one could be AES as well but shouldn't I still see page structure?
PostPosted: April 19th, 2016, 14:37
The point I'm making is that the following relationship should hold true, AISI:
    User accessible capacity + Available OP Sector Count = total capacity of NAND array
However, the numbers suggest that the total capacity of the NAND array is 512GiB + 8GiB rather than 512GiB. This in turn suggests that each chip has a capacity of 32.5GiB. Therefore the SMART attributes don't make sense.
Users browsing this forum: No registered users and 14 guests
