HDD GURU FORUMS
http://forum.hddguru.com/
Error ocz vertex 3 sata III 2.5 ssd 240gb not detect
http://forum.hddguru.com/viewtopic.php?f=10&t=33302
Page 1 of 1
Author:  datahdd116 [ April 18th, 2016, 8:50 ]
Post subject:  Error ocz vertex 3 sata III 2.5 ssd 240gb not detect
hello guys,
long story short SSD ocz vertex 3 sata III 2.5 240gb I did not detect on bios
But there are pictures on the SSD
how i can fix this problem?
HELP ME
Author:  HaQue [ April 18th, 2016, 20:02 ]
Post subject:  Re: Error ocz vertex 3 sata III 2.5 ssd 240gb not detect
being SandForce based you should hope it is an electronic issue with a failed component or power supply issue. Have you examined the circuit board under a microscope for any obviously blown parts? maybe some good pics of both sides of the PCB may help in diagnosis
Author:  datahdd116 [ April 18th, 2016, 23:11 ]
Can you help me
Author:  fzabkar [ April 24th, 2016, 18:32 ]
Do you get anything on the PWR and FLT LEDs?
Can you get a log from the serial port (TX/RX)?
Do you have a multimeter and do you know how to use it?
http://www.phpbb.com/
