Intel SSD 320 600GB 8MB bug
http://forum.hddguru.com/viewtopic.php?f=10&t=33494
Author:  Scenic [ May 21st, 2016, 16:21 ]
Post subject:  Intel SSD 320 600GB 8MB bug
Hello
model ssdsa2bw6000g3 600GB
F/W 4pc10362
Flash Winbond 4 Mb
appendage
I have a programmer
someone has copies of the rom?
rom.rar [15.88 KiB]
Downloaded 553 times
Author:  bubaleh [ May 23rd, 2016, 4:22 ]
Post subject:  Re: Intel SSD 320 600GB 8MB bug
You have BAD_CTX issue, as i see at screenshots. So the problem is in Context module, that storing in NAND chips. You dont need do anything with ROM dump, it's fine.
PC3000 SSD supports drives with this issue. And i'm afraid, I've not heard about other tool that could handle it.
Author:  Scenic [ May 23rd, 2016, 13:25 ]
pc 3000 ssd is able to fix it?
Did you check rom is okay?
You can toss me rom with this drive?
I do not have pc 3000. Sent him to the site where they have this tool.
I do not write well in English .
Author:  bubaleh [ May 24th, 2016, 4:49 ]
It can do both: data recovery and repairing the drive. But so far as you dont have the pc3000 it would be too expensive to buy it just for this case. Try to find someone who has it.
I almost sure ROM is Ok, because you have BAD_CTX issue. As i know there is nothing interesting in ROM except the bootloader. But drive sucessfully starts main firmware. That means the bootloader is fine.
I'm afraid, I dont have the EEPROM dump for 600 GB drive.
Author:  Scenic [ May 24th, 2016, 12:12 ]
OK thanks
How much is pc3000sd?
You can buy the same pc3000ssd or together with PC3000?
I live in Poland
Author:  HaQue [ May 24th, 2016, 18:30 ]
you can, but it will be double the price! go have a look at ace's website and get a quote..
Author:  darkforce1 [ May 27th, 2016, 8:47 ]
HaQue, which double price? You buy PC-3000 Express or UDMA for HDD recovery and buy PC-3000 SSD for SSD recovery.
Or what do you mean?
Author:  HaQue [ May 27th, 2016, 8:57 ]
Scenic wrote:
OK thanks
Well buying 2 separate products is twice as expensive as just PC3000SSD
Author:  darkforce1 [ May 27th, 2016, 10:01 ]
It depends what you need. If you need to recover only this SSD, try to find anyone who has PC-3000 SSD. If you have a lot of SSD, PC-3000 SSD is worth it.
