| Sandisk CF 128GB http://forum.hddguru.com/viewtopic.php?f=10&t=33527 |
Page 1 of 1 |
| Author: | arvika [ May 26th, 2016, 13:13 ] |
| Post subject: | Re: Sandisk CF 128GB |
No. This controller not crypt data. Usually it is rebranded SM controller. |
| Author: | einstein9 [ May 26th, 2016, 13:43 ] |
arvika wrote: No. This controller not crypt data. Usually it is rebranded SM controller. Thnx Michal, am dumping it now, might need your help later Will let u know |
| Author: | Dmitri [ May 26th, 2016, 14:07 ] |
Generally this is to be told with the card or the dump on hands, but chances are that proper translator-based reassembly won't be possible. We mostly get these of 64 GB capacity, but worked with the larger ones as well. What kind of data you're looking to recover? Photos should be pretty recoverable, but videos will be PITA to get back. And yes, that's not SanDisk, but relabeled SM2236. Memory chips are Toshiba and relabeled as well. Check the number of memory banks in the chip. P.S. And where's one more chip? |
| Author: | pcimage [ May 26th, 2016, 15:27 ] |
Agree, not encrypted. We have done many 32gb and 64gb versions but not yet 128gb. |
| Author: | arvika [ May 26th, 2016, 18:12 ] |
Dmitri wrote: Generally this is to be told with the card or the dump on hands, but chances are that proper translator-based reassembly won't be possible. ... What kind of data you're looking to recover? Photos should be pretty recoverable, but videos will be PITA to get back. Problem with videos is only for Sandisk controller. For rebranded SM controller video is ok. Translator can be rebuild correctly. In FE there is problem with videos file - IMHO bad assembling algorithm. I have much more better result with videos when I assembling Sandisk controllers in VNR. |
| Author: | einstein9 [ May 28th, 2016, 3:37 ] |
@ Dmitri 4 chips 4 banks @ pcimage me too @ arvika Images required only reading dumps takes long time, sometimes i forget to switch chips and continue thank you guys |
