Pinout of monolithic SDHC MMBGF08GWACA-GE 8GB
http://forum.hddguru.com/viewtopic.php?f=10&t=33642
Author:  PanaFan [ June 17th, 2016, 3:14 ]
Post subject:  Pinout of monolithic SDHC MMBGF08GWACA-GE 8GB
Hello everyone;
I have a monolithic SDHC, it seems that the controller is damaged and i can“t get the data from it, so i would like to know if there a possibility o recover the data from it, by connecting some wires to monolithics adapter, as PC 3000 adapter, The pictures below shows the type SDHC that i have. I'm not finding any kind of this SD Card. Any sugestions?
Thank you very much.
Author:  arvika [ June 17th, 2016, 16:45 ]
Post subject:  Re: Pinout of monolithic SDHC MMBGF08GWACA-GE 8GB
I have this pinout. http://odzyskiwanie-danych.com.pl/image ... arvika.jpg
This could be tricky case. In this case probably there is two XORs (grid + standard XOR).
Last time I have similar case which was solved. It looks like this:
Author:  pcimage [ June 17th, 2016, 16:51 ]
Yes, very complicated case.
Not for the beginner!
Let Arvika handle the case for you, not many others can help with this nightmare :-(
Author:  ddrecovery [ June 17th, 2016, 17:27 ]
WTF.. Arvika you are a genius...... :shock:
Author:  Amarbir[CDR-Labs] [ June 18th, 2016, 11:24 ]
Well,
In flash he is
