 Post subject: Pinout Needed
PostPosted: May 20th, 2016, 16:44
PNY 64GB SDXC. This is new and not available through VNR or PC3K.
 Post subject: Re: Pinout Needed
PostPosted: May 20th, 2016, 22:16
Hi, given that the SD contacts are 9 1 2 3 4 5 6 7 8, and 3=GND, 4=VCC
columns are labelled A B C D left to right, and pads rows are labelled 1 to 9 starting from the top. upper left round pad is A-1 for example.
could you test each round pad with both GND and VCC using a DMM continuity beep and show which of the round pads are vcc or gnd? I am thinking this one will be 16-bit bus.
PostPosted: May 25th, 2016, 19:59
Hi HaQue, sorry for the slow response been one of those weeks. Should be able to get to this tomorrow.
PostPosted: June 4th, 2016, 15:51
Hey, the only continuity is Vcc at B9. This is consistent with SDHC Type 2, which also only has one Vcc at C7 and no ground. Not sure if that helps is too much ?
PostPosted: July 4th, 2016, 11:30
Sunny had a pinout like this as I recall
PostPosted: July 5th, 2016, 12:00
Do you know Sunnys username?
PostPosted: July 5th, 2016, 12:45
networkpc3000
PostPosted: July 5th, 2016, 12:52
pcimage wrote:
networkpc3000
