Windowx XP Embedded CF card , D partition not shown EWF
http://forum.hddguru.com/viewtopic.php?f=10&t=34010
Author:  sanjurk [ August 19th, 2016, 13:37 ]
Post subject:  Windowx XP Embedded CF card , D partition not shown EWF
I have almost as same problem as in
https://forum.hddguru.com/viewtopic.php?t=23643&start=
I have cloned a CF disk. The cloned disk boots on Windows XP Embedded,but doenst show the D:, or the d partition . The D partition has the data which are needed for an installlation. After booting, the D drive doesnt how up.
I had plugged the CF card using a card reader and on using disk internals research - it does show up that the D drive is present, but while booting it in the original systeme of windows xp embedded it doesnt show up.
Can someone please help me with it.
Author:  fzabkar [ August 19th, 2016, 15:20 ]
Post subject:  Re: Windowx XP Embedded CF card , D partition not shown EWF
What is the brand and model?
Author:  sanjurk [ August 20th, 2016, 7:15 ]
Sandik Extreme III
Compact Flash
20MB/s
2GB
I read through certain forum that the brand and model will be a problem, but this disk was working fine in a display unit, which it was plugged in. I also have the same disk that is in another display from which I cloned it- and had put it in the above and isnt showing up the d drive partition.
Author:  fzabkar [ August 20th, 2016, 16:02 ]
Try SanDisk's ATCFWCHG tool to convert your CF card from "removable" to "fixed".
viewtopic.php?f=10&t=31965
Author:  sanjurk [ August 21st, 2016, 14:20 ]
To be honest - It seems atcfwchg.com, its quite complicated.
I am able to boot to Windows XP Embedded, but is there anything that I could do from windows to enable the partition.
I am searching google and couldnt get the tool. Is there any instruction that could be given to make the D: drive partition active.
