HDD GURU FORUMS
http://forum.hddguru.com/
Must I say Goodbye to this PenDrive?
http://forum.hddguru.com/viewtopic.php?f=10&t=34068
Page 1 of 1
Author:  hack3rcon [ August 27th, 2016, 2:16 ]
Post subject:  Must I say Goodbye to this PenDrive?
Hello.
I have a Flash drive with below information :
Bus 003 Device 004: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) 64MB QDI U2 DISK
I did below commands on Linux and you can see their result :
sudo mkfs.ext2 /dev/sdc
mke2fs 1.42.5 (29-Jul-2012)
/dev/sdc is entire device, not just one partition!
Proceed anyway? (y,n) y
/dev/sdc: Read-only file system while setting up superblock
sudo fsck -fy /dev/sdc
fsck from util-linux 2.20.1
e2fsck 1.42.5 (29-Jul-2012)
fsck.ext2: Read-only file system while trying to open /dev/sdc
Disk write-protected; use the -n option to do a read-only
check of the device.
sudo hdparm -r0 /dev/sdc
/dev/sdc:
setting readonly to 0 (off)
readonly      =  0 (off)
sudo dumpe2fs /dev/sdc
dumpe2fs 1.42.5 (29-Jul-2012)
dumpe2fs: Bad magic number in super-block while trying to open /dev/sdc
Couldn't find valid filesystem superblock.
How can I fix it?
Author:  rogfanther [ August 27th, 2016, 13:37 ]
Post subject:  Re: Must I say Goodbye to this PenDrive?
If you were formatting it, there isn´t data in it that you need to keep, right ?
Then, can you try
*** CAUTION -> MAKE SURE YOUR USB DRIVE IS REALLY /DEV/SDC ***
sudo dd if=/dev/zero of=/dev/sdc
and post the result here ?
Author:  fzabkar [ August 27th, 2016, 17:06 ]
What capacity is reported by the device?
Doesn't the "read-only" error suggest that the flash drive has run out of spare blocks?
I believe the following command should attempt to read sector 0:
    sudo dd count=1 bs=512 if=/dev/sdc of=sector0.bin
Author:  hack3rcon [ August 28th, 2016, 2:29 ]
Then, can you try
dd: opening `/dev/sdc': Read-only file system
http://www.phpbb.com/
