| Kingston SMSM151S3128GD msata PCIe SSD failed http://forum.hddguru.com/viewtopic.php?f=10&t=34117 |
Page 1 of 1 |
| Author: | TKA9 [ September 5th, 2016, 15:26 ] |
| Post subject: | Kingston SMSM151S3128GD msata PCIe SSD failed |
Hello, I went back to my laptop only to find it in BIOS. Sometimes it's detected, sometimes it's not. I put it in an enclosure, windows disk manager detects it briefly but it disappears without even showing up in the explorer. I tried IDE mode and XP, still won't show up. Can SSDs have bad sectors (nand cell)? Is it the controller? Is there any software that looks past whatever part that's damaged? |
| Author: | TKA9 [ September 5th, 2016, 16:25 ] |
| Post subject: | Re: Kingston SMSM151S3128GD msata PCIe SSD failed |
Quote: Windows has stopped this device because it has reported problems. (Code 43) The USB set address request failed. Also Quote: Matching Device Id: USB\SET_ADDRESS_FAILURE
| Author: | fzabkar [ September 5th, 2016, 16:33 ] |
If the SSD stays up for long enough, try to obtain a SMART report. You could use CrystalDiskInfo for this. |
| Author: | labtech [ September 5th, 2016, 17:19 ] |
TKA9 wrote: Can SSDs have bad sectors (nand cell)? YesTKA9 wrote: Is it the controller? Likely notTKA9 wrote: Is there any software that looks past whatever part that's damaged? Yes, professional software may help.
| Author: | TKA9 [ September 6th, 2016, 0:31 ] |
fzabkar wrote: If the SSD stays up for long enough, try to obtain a SMART report. You could use CrystalDiskInfo for this. I'll try to catch it. edit Nope. Crystaldiskinfo won't detect it. Even when it was showing in device manager. TKA9 wrote: Is there any software that looks past whatever part that's damaged? Yes, professional software may help.[/quote]Such as what? |
| Author: | labtech [ September 6th, 2016, 9:23 ] |
PC3000 SSD |
| Author: | TKA9 [ September 7th, 2016, 0:11 ] |
labtech wrote: PC3000 SSD I just did a quick research and it's expensive as hell. Anything that doesn't cost more than a car? |
| Author: | jermy [ September 7th, 2016, 7:08 ] |
I think its cheaper than a Lamborghini rolls Royce or a maybach |
| Author: | lcoughey [ September 7th, 2016, 8:54 ] |
TKA9 wrote: labtech wrote: PC3000 SSD I just did a quick research and it's expensive as hell. Anything that doesn't cost more than a car? Send to a data recovery pro. |
