32GB SD-Card Got Write Protected.
http://forum.hddguru.com/viewtopic.php?f=10&t=34206
Author:  DarkCoder [ September 25th, 2016, 15:05 ]
Post subject:  32GB SD-Card Got Write Protected.
Hello.. !!
Long STory Short , My SD card got Write Protected . How i fix this ..?? i almost Tried every available method on GooGle and Youtube but No Luck , Tried HDD Low Level Format Too , keep getting offset and I/O device error..
i Know how to fix Write Protected USB by using Mass Production Tool ( Reprogram Controller and STuff ) but i am Unable to find any such Tools for MicroSd card .. is their no SUch Tool which Re-Flash Firmware of SD card COntroller and fix this stupid Write Protection thing WHich making millions of People SD cards USELESS.. :?
i ALso Tried editing HEX values of SD card using HEX editor but No luck , Everything Keeps coming back when i reinsert my SD card..
WHy these SD card makers don't provide Tools which can fix these Write Protected issue easily or are they Too Greedy and don't care about their customers .. !!?
Hope SOmeone help me Out.. ( Please AVoid STupid Solutions Like use DIskPart , MiniTool Partition Recovery , Format From Gparted etc if Possible , These types of Crap Never Works against WRite Protected Issue :? )
(i don't Care about DATA , just Want my SD card to be fixed , can't afford new one right now.. :( )
Thanks..
Author:  labtech [ September 25th, 2016, 18:25 ]
Post subject:  Re: 32GB SD-Card Got Write Protected.
It is in write protected mode because it is damaged/degraded. Cannot quite fix, as it is not so much about the tools, but about the device itself.
Just recover your files and save to something more affordable or free.
Author:  DarkCoder [ September 26th, 2016, 11:19 ]
i don't think it's Damaged or degraded , i did SUrface SCan Test ( Read Test only ) and found zero Bad sectors..
Also this same happens to me a year ago , when my USB got Write-protected and many Experts said that it's Hardware fault and USB is dead and then i found out these MP TOOLS , this fixed my USB and still that USB is Working fine .... :/ SO...!!??/
Author:  labtech [ September 26th, 2016, 11:34 ]
So, logically, why would the same tool NOT work again if the circumstances are presumably similar?
Author:  DarkCoder [ September 26th, 2016, 12:36 ]
Because this time it's SD card , Not USB flash Drive... their are no MP Tool available for SD card ( Don't Know why)...
Author:  labtech [ September 26th, 2016, 16:02 ]
Sorry, got confused about the devices.
Do you have a link to this MP Tool? Curious to see what tool this is.
Author:  DarkCoder [ September 27th, 2016, 5:24 ]
Here See these Links ..
http://www.usbdev.ru/
http://flashboot.ru/
Found this Too ..
https://forum.hddguru.com/viewtopic.php ... ile=mobile
