Strange memory chip
http://forum.hddguru.com/viewtopic.php?f=10&t=34450
Author:  Miss Di [ November 2nd, 2016, 10:37 ]
Post subject:  Strange memory chip
I got an 8 GB pen with a stange memoy chip as picture attached.
Any idea how can I extract the memory chip to recover data using PC3000?
Thanks,
^BCBB366AB6E5FD3F651A974E9D4E0E6DCC425AFA330E2DCAC3^pimgpsh_fullsize_distr.jpg [ 1.36 MiB | Viewed 7473 times ]
^3CF2DE61E5E709B1818635C70EA05B28A17EAE028794155B31^pimgpsh_fullsize_distr.jpg [ 1.05 MiB | Viewed 7473 times ]
Author:  arvika [ November 2nd, 2016, 11:42 ]
Post subject:  Re: Strange memory chip
Find datasheet for controller. Connect to memory chip from controller side.
Author:  data-medics [ November 2nd, 2016, 11:55 ]
I'd bet there's a NAND of some sort buried under that blob of tar. Getting it out in one piece might not work so well. Probably best to do what Arvika says.
Author:  Miss Di [ November 2nd, 2016, 11:58 ]
Thanks for the suggestions but what do you mean by "Connect to memory chip from controller side"?
Author:  arvika [ November 2nd, 2016, 12:21 ]
Remove controller and connect reader to memory chip by wire.
Author:  Forhad Hossen [ December 23rd, 2016, 10:07 ]
Ok, This is not such a big problem. Check the datasheet for the controller.
