 Post subject: Sony 64GB Tough SD Card NAND Recovery
PostPosted: May 29th, 2023, 12:07
Hello ,
I have this Sony SD Card 64GB that the customer gave in for recovery .The sectors are all ZERO and i would like to preform a NAND recovery to see if i can recover data or not ,Problem is how to get access to NAND protocol in this card ,What to remove and were to probe .
Top Photo
CDRLabs - Case No 04670 Top [Sony 64GB Tough SD Card Data Recovery].jpg [ 165.39 KiB | Viewed 3073 times ]
Bottom Photo
CDRLabs - Case No 04670 Bottom [Sony 64GB Tough SD Card Data Recovery].jpg [ 129.64 KiB | Viewed 3073 times ]
 Post subject: Re: Sony 64GB Tough SD Card NAND Recovery
PostPosted: May 30th, 2023, 7:53
http://www.flash-extractor.com/library/ ... 98_b3__1x4
Very hard to access to NAND protocol, this plastic housing is glued to SD PCB.
Probably 2K LDPC - good luck!
PostPosted: May 30th, 2023, 13:54
Gregory wrote:
http://www.flash-extractor.com/library/Monolith/SD/Part%203/Monolith%20SD_38__98_3c_98_b3__1x4
Hi ,
If Its LDPC no point in trying too ,I wonder when these vendors will have a solution for LDPC
PS : Thanks for reply brother ,You are based in poland ,do you have a data recovery company or you work at a data recovery company
Users browsing this forum: No registered users and 137 guests
