Microscope Update - Assistance And Help Required
Posted: December 31st, 2016, 15:00
Hello ,
I Have The Following Microscope With 3 Steps Magnification 10x,20x and 40x .I Have Used This When i Started Working With SMD's And Then Hard Drive Head Inspection .This is The Microscope i Have - > http://quasmoindianmicroscope.com/?prod ... croscope-2 .I Would Be Having a Small Laminar Flow Bench In My Classroom Around April 2017 .I Plan To Shift This Microscope To That Place That Time .I Am Having Two Separate Enclosed Rooms Now With 90Inch Wide Laminar Flow Benches [ 1 Room Is Operational Second Room Is Awaiting a Laminar But Constructed ] . Plan Is To Do 3.5" Drives In One Room And 2.5" In The Other .In a Separate Room i Plan To Install 3 Work Tables [ 1 Is Already Operational ] ,2 are pending Purchase .Central Table Will Handle All SMD Work Related To HDD's and NANDS and The Two Side Tables Will Handle Dedicated BGA Machines And High End SMD Machine " I Could Also Shift My Current Microscope To That Section Dedicatedly To Handle SMD Work " .I Am Wanting To Upgrade My Microscope To a Good Simul Focal Stereo Zoom Microscope With Good Quality Camera And Light System " But i Can Buy The Camera Later On Too " .I am Seeing Two Types Focal Working Distance 8" And 4" , Which Is Good For Hard Drive Inspection " Platters " And Hard Drive Heads .Will i Have Space To Put Them In My Current Laminar Flow Setup Which is 90Inch Wide OR Shall i Buy a Separate Laminar Flow With Just a Microscope For Inspection Work " If i Do i Will Need To Carry Heads and Platters [ Complete HDA Assembly ] " From Those Two Dedicated Sections To This Third Laminar Flow Bench " .I Am Not Finding Much Options in India and i Have Decided To Go With Amscope In USA That Will Ship Goods To My Torrance USA Forwarder Address And i Will Import It To India From There .I Have Seem Dimitry Sirs Scope In His Office It Seems To Me Like a Boom Stand Model .Now Boom Stands Are Of Two Types Single Arm and Dual Arm .i Think Dual would Be Better " But i May Be Wrong " . Whats The Maximum Magnification i Should Be Looking At When We Talk About Hard Drives And When We Talk About NAND Work .This is Something That i Have Narrowed Into .My Max Budget Is USD 750/- Currently - > http://www.amscope.com/catalogsearch/re ... imul+focal .Please Help Me Find a Good Model For My Work From This List i Have Given a Link To
