 Post subject: Cracked Micro SD, possible to recover?
PostPosted: January 9th, 2017, 17:42
Got a cracked Sandisk Ultra PLUS 64gb micro SD with a fracture running through it. See attached photos.
Would it be possible to recover this using monolith tools?
 Post subject: Re: Cracked Micro SD, possible to recover?
PostPosted: January 9th, 2017, 17:43
Of course, some traces would have to be repaired on the surface, but is there any way to tell if it's damaged even more internally?
PostPosted: January 9th, 2017, 17:44
IMHO no.
PostPosted: January 10th, 2017, 0:22
Well I completely believe you but I figure it can't hurt to try. Just gotta get a micro SD reader now.
PostPosted: January 10th, 2017, 4:39
Yes, worth to try, but memory module in MicroSD cards usually cover all surface of card (inside). So any crack usually destroy the memory module.
PostPosted: January 10th, 2017, 4:44
Reminds me of a YouTube video I watched today..... 8)
PostPosted: January 10th, 2017, 5:47
Not Possible,Just Under 10% Chance It Can Work .If You See a Good Xrayed Image Of a Micro SD You Will Understand It Has a Lot Of Tracks Inside It .In You Case You Repaired Just The Top Once ,But Worth a Try
PostPosted: January 10th, 2017, 10:12
Same card as yours, most likely dead.
VISUAL NAND RECONSTRUCTOR. Since 2014.
PostPosted: January 11th, 2017, 4:09
Holy crap. Touched it up a bit and guess what??
Didn't work. Thanks for the input though :roll:
PostPosted: January 11th, 2017, 10:19
Impressive soldering. What gear do you use?
PostPosted: January 11th, 2017, 15:20
Hakko T9-I but it's still too big for this.
PostPosted: January 12th, 2017, 9:54
Nice Try And Effort ,Good Job
PostPosted: January 17th, 2017, 4:55
WTF!!! Is this the infamous Jason of the Rossmann Group?
https://www.youtube.com/watch?v=H9Apcy8GyIM
Normally I'd congratulate but I feel pity for you, 2hrs spent soldering for a hopeless case.
Recover My Flash Drive
PostPosted: January 17th, 2017, 6:32
Be careful, Louis might make us watch another "The world according to Louis video". :mrgreen:
Users browsing this forum: No registered users and 29 guests
