HDD GURU FORUMS
http://forum.hddguru.com/
Cracked Micro SD, possible to recover?
http://forum.hddguru.com/viewtopic.php?f=10&t=34793
Page 1 of 1
Author:  JGAN [ January 9th, 2017, 17:42 ]
Post subject:  Cracked Micro SD, possible to recover?
Got a cracked Sandisk Ultra PLUS 64gb micro SD with a fracture running through it. See attached photos.
Would it be possible to recover this using monolith tools?
Author:  JGAN [ January 9th, 2017, 17:43 ]
Post subject:  Re: Cracked Micro SD, possible to recover?
Of course, some traces would have to be repaired on the surface, but is there any way to tell if it's damaged even more internally?
Author:  arvika [ January 9th, 2017, 17:44 ]
IMHO no.
Author:  JGAN [ January 10th, 2017, 0:22 ]
Well I completely believe you but I figure it can't hurt to try. Just gotta get a micro SD reader now.
Author:  arvika [ January 10th, 2017, 4:39 ]
Yes, worth to try, but memory module in MicroSD cards usually cover all surface of card (inside). So any crack usually destroy the memory module.
Author:  thatdellguy [ January 10th, 2017, 4:44 ]
Reminds me of a YouTube video I watched today..... 8)
Author:  Amarbir[CDR-Labs] [ January 10th, 2017, 5:47 ]
Not Possible,Just Under 10% Chance It Can Work .If You See a Good Xrayed Image Of a Micro SD You Will Understand It Has a Lot Of Tracks Inside It .In You Case You Repaired Just The Top Once ,But Worth a Try
Author:  Sasha Sheremetov [ January 10th, 2017, 10:12 ]
Same card as yours, most likely dead.
Author:  JGAN [ January 11th, 2017, 4:09 ]
Holy crap. Touched it up a bit and guess what??
Didn't work. Thanks for the input though :roll:
Author:  larsjorgen [ January 11th, 2017, 10:19 ]
Impressive soldering. What gear do you use?
Author:  JGAN [ January 11th, 2017, 15:20 ]
Hakko T9-I but it's still too big for this.
Author:  Amarbir[CDR-Labs] [ January 12th, 2017, 9:54 ]
Nice Try And Effort ,Good Job
Author:  jeremyb [ January 17th, 2017, 4:55 ]
WTF!!! Is this the infamous Jason of the Rossmann Group?
https://www.youtube.com/watch?v=H9Apcy8GyIM
Normally I'd congratulate but I feel pity for you, 2hrs spent soldering for a hopeless case.
Author:  thatdellguy [ January 17th, 2017, 6:32 ]
Be careful, Louis might make us watch another "The world according to Louis video". :mrgreen:
http://www.phpbb.com/
