 Post subject: VFBGA63 chip on memory stick with AU6983
PostPosted: March 7th, 2017, 12:37
Hello all,
I've just received in a memory stick using a VFBGA63 chip (NQ280 Micron). I don't think this is eMMC as there is a pretty standard AU processor on the memory stick. I've not seen this type of chip in, and do not have any adapters to try and take a read out. Does anyone?
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
 Post subject: Re: VFBGA63 chip on memory stick with AU6983
PostPosted: March 7th, 2017, 14:49
http://www.ebay.de/itm/U08631-VFBGA63-B ... 1990452089
If you will got adapter you convert it to any other existing device
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: March 7th, 2017, 14:57
Don't have an adaptor, but I believe this is the pinout...
http://www.macronix.com/Lists/Datasheet ... 20v1.3.pdf
PostPosted: March 8th, 2017, 5:20
Cheers. Given it's unlikely to ever see on of these chips in again the cost associated with adapter is probably not worthwhile for a one off job. Thanks though for pointing it out and the PDF of specifications.
The customer does have a copy of the data on a failed HDD too. It's Samsung M9 series with heads stuck to the platter. If I have the choice of wiring in to the pins of the BGA or replacing the heads on the HDD... well I think we all know the what we would choose.
I'll make a check with one or two others to see if they hold the adapter in stock.
Thanks,
John
0161 408 4857
Users browsing this forum: No registered users and 28 guests
