| SanDisk U110 SSD 128gb firmware http://forum.hddguru.com/viewtopic.php?f=10&t=35280 |
Page 1 of 1 |
| Author: | tomis [ April 24th, 2017, 10:15 ] |
| Post subject: | SanDisk U110 SSD 128gb firmware |
Hello, I've uploaded a few other firmware, sandisk 128GB firmware u221000. I uploaded from usb after uploading a message that everything ok to do a computer restart.Now from now the disk is dead does not detect it bios.Is it possible to rescue it or a garbage? Please support me because I'm a little pity him. |
| Author: | fzabkar [ April 24th, 2017, 17:56 ] |
| Post subject: | Re: SanDisk U110 SSD 128gb firmware |
I probably won't be able to help you, but could you provide a link to your update? |
| Author: | tomis [ April 25th, 2017, 1:18 ] |
There is no software Original Maybe other firmware? https://kb.sandisk.com/app/answers/deta ... on-x2316rl |
| Author: | fzabkar [ April 25th, 2017, 3:06 ] |
IIUC, you have applied the firmware update for a SanDisk Ultra Plus (SDSSDHP / SDSSDH2) to a U110. The former has a Marvell SS889175 controller whereas the latter has a SanDisk controller (?). AIUI, these updates are at least partially written to the NAND array rather than a discrete memory chip. Therefore I can't see any DIY solution, even if you were able to find your original firmware. |
| Author: | HaQue [ April 25th, 2017, 6:12 ] |
how/why did it "let him" do it?? most firmware I've ever seen do at least a rudimentary sys check to make sure it is compatible |
