Martin wrote:HaQue wrote:Pretty sure this is a 16bit nand chip.
Exactly.
Have you tried 16-8 configuration? where chip is wired as 16-bit but read as 8?
Also forgot to ask, does it ID correctly and what is the issue you are having, bit errors, bad read or other?
Martin wrote:HaQue wrote:some of the early sandisks are encrypted
It is optional and user didn't use this option.
No, I mean natively by controller and transparent to user.
Example, some 20-82-00162-1's are encrypted, but I have had some not, all 20-82-00162-2's I have in my database are. I have one 20-99-00128-3 that is encrypted and one that isn't, but everything else is exactly same..chip, pcb.
You can tell by looking at hex dump. From memory it looks like a 64 bytes from offset 0x0 then 00's till encrypted data, but I can check exactly if you need. It may not be encryption, but some kind of dynamic XOR or other algo, but I don't think it has ever been identified/reversed.
Martin wrote:HaQue wrote:But the ones that arent can have fairly complex mix's such as 3 block pairs, rotating pages in the block, mixing data between blocks etc. Also most need some divide on the markers.
You are talking about assembling operations, my main question is about memory chip configuration, I can't read the chip correctly.
Are you sure of the number, and it isn't SDTN instead? I think the ID should be 45xCEx9AxC3 maybe you have a dirty/broken pin and not ID correctly?
Martin wrote:HaQue wrote:What tools do you have for flash?
PC3000 Flash. And by your terminology, probably, you are using SC FE, but they do not have a config as well. So may be some guy with a different tools will help, I'm not sure.
HaQue wrote:Datasheets for controllers dont exist, and havent seen many useful SanDisk Nand datasheets either.
It exists, but with NDA it is very complicated to get this, I have no such "contacts"
I know! SanDisk, when they finally responded told me data recovery was not a valid reason for getting access. For Micron NDA, I had to talk to a Micron person for Micron/Spectek, but eventually they were reasonable. SanDisk, for having so much clout and input in Flash are exceptionally non-helpful, and pretty much couldn't give a toss about standards either.
I am using SC terminology but it is similar in VNR, VNR has this chip config. Depending on where you are, you could get a read from someone. lots of VNR people in Poland for example.
