| SM2246XT http://forum.hddguru.com/viewtopic.php?f=10&t=35425 |
Page 1 of 1 |
| Author: | fzabkar [ June 1st, 2017, 17:04 ] |
| Post subject: | Re: SM2246XT |
Here is a DIY development kit (US$22). Perhaps you could ask the seller for firmware and hardware development tools or documentation? SSD PCBA Kits, SSD DIY, Flash Memory Interface BGA152/132, SM2246XT H AA, SATA6Gb/s Interface, SM2246HX, 4CH 4CE 4-LAND NAND Flash https://www.aliexpress.com/item-img/SSD-PCBA-KITS-SSD-DIY-PCBA-Flash-Interface-BGA152-132-SM2246XT-H-Controller-SATA6Gb-s-Interface/32543701998.html |
| Author: | sempre [ June 2nd, 2017, 13:48 ] | ||
| Post subject: | Re: SM2246XT | ||
sempre wrote: Hello!
Please, Show me on the pcb what points for safe mode? look photo
Please, Show me on the pcb what points for safe mode? look photo |
| Author: | fzabkar [ June 2nd, 2017, 14:30 ] |
You have shown us the JTAG port and a serial communications port. |
| Author: | sempre [ June 2nd, 2017, 16:01 ] | ||
fzabkar wrote: You have shown us the JTAG port and a serial communications port.
| Author: | fzabkar [ June 2nd, 2017, 16:13 ] |
The development kit has similar test points (ROM, ISP, HWP). These kits are useless without docs or software tools. That's why I suggested that the seller may have documentation that could help you. |
| Author: | fzabkar [ June 2nd, 2017, 17:55 ] |
FWIW, SanDisk's Z400S SSD has a JTAG edge connector (J1) plus a single pair of ROM pads. Perhaps the ROM pads are the answer? http://pc.zoznam.sk/plextor-m6v-vs-sandisk-z400s-aky-vplyv-na-vykon-ssd-ma-dram-cache?page=2 |
| Author: | sempre [ June 6th, 2017, 9:21 ] | ||
fzabkar wrote: FWIW, SanDisk's Z400S SSD has a JTAG edge connector (J1) plus a single pair of ROM pads. Perhaps the ROM pads are the answer? http://pc.zoznam.sk/plextor-m6v-vs-sandisk-z400s-aky-vplyv-na-vykon-ssd-ma-dram-cache?page=2 Thanks all helps!! Sorry, Did not enter safe mode. Is busy 100%.
| Author: | sempre [ June 6th, 2017, 10:14 ] |
fzabkar wrote: FWIW, SanDisk's Z400S SSD has a JTAG edge connector (J1) plus a single pair of ROM pads. Perhaps the ROM pads are the answer? http://pc.zoznam.sk/plextor-m6v-vs-sandisk-z400s-aky-vplyv-na-vykon-ssd-ma-dram-cache?page=2 YES!! CORRECT!! THANKS! |
| Author: | fzabkar [ June 6th, 2017, 16:32 ] |
I'm wondering whether a general method that could apply to all flash based devices would be to short the NAND or controller R/B* pins (open drain) to ground during power-on. I have recently seen one SSD that does it this way. |
| Author: | fzabkar [ July 2nd, 2018, 17:45 ] | |||
| Post subject: | Re: SM2246XT | |||
SM2246EN_Datasheet_v03_20140117.rar http://bbs.liangchanba.com/forum.php?mod=attachment&aid=MTI1OTZ8OGUzYjZlYzd8MTUzMDUxNTI4N3wwfDMxMTcx
| Author: | fzabkar [ July 2nd, 2018, 18:14 ] | |||
Just FYI, Transcend's TS6510 controller is a rebranded SM2246XT (DRAM-less version of SM2246EN). http://www.siliconmotion.com/A6.1.Detail_News.php?sn=184 Quote: The SM2246EN is an ultra high-performance and low power SATA 6Gb/s SSD controller supporting 1y/1z nm MLC NAND from all major NAND suppliers. ... The SM2246XT is a DRAM-less SATA 6Gb/s SSD controller ...
| Author: | reco [ November 16th, 2018, 23:11 ] |
thanks for sharing. hddguru is still a good place for me to keep learning stuff. |
