| Is my HDD dead? http://forum.hddguru.com/viewtopic.php?f=10&t=35558 |
Page 1 of 1 |
| Author: | hack3rcon [ July 12th, 2017, 6:54 ] |
| Post subject: | Is my HDD dead? |
Hello. I have an external A-DATA HDD and when I plugged it to my system then it can't be mounted. Code: $ lsusb Bus 004 Device 002: ID 8087:8000 Intel Corp. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 8087:8008 Intel Corp. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 007: ID 125f:a15a A-DATA Technology Co., Ltd. When I use "testdisk" for recover it then : Code: TestDisk 6.14, Data Recovery Utility, July 2013 Christophe GRENIER <grenier@cgsecurity.org> http://www.cgsecurity.org Disk /dev/sdc1 - 1000 GB / 931 GiB - CHS 953867 64 32 Partition Start End Size in sectors No partition found or selected for recovery Any idea? Thank you. |
| Author: | fzabkar [ July 12th, 2017, 15:52 ] |
| Post subject: | Re: Is my HDD dead? |
Can you retrieve a SMART report with smartmontools? Can you read sector 0 with dd or a hex editor? |
