| Is this any good? http://forum.hddguru.com/viewtopic.php?f=10&t=35970 |
Page 1 of 1 |
| Author: | speakerbox [ October 19th, 2017, 10:00 ] |
| Post subject: | Is this any good? |
Just to dump the binary file from a TSOP48 https://es.aliexpress.com/store/product ... 69399.html Was going to buy the flash extractor reader if not Many thanks in advance! |
| Author: | arvika [ October 19th, 2017, 17:20 ] |
| Post subject: | Re: Is this any good? |
Bad solution. For nand flash better buy Flash Extractor reader, it is quite cheap, but very good if you want only dump the memory and outsource it. |
| Author: | HaQue [ October 19th, 2017, 19:52 ] |
If you look at the chip support, it is mainly firmware type chips on IOT devices this may be suited for.. 2GB and under. Also there is no data recovery software which is as important as the dumping of the chip. Agree with Arvika. |
