| Monolith SD Card Sandisk - > 8 Bit Or 16 Bit Pinout Wiring http://forum.hddguru.com/viewtopic.php?f=10&t=35999 |
Page 1 of 1 |
| Author: | Amarbir[CDR-Labs] [ October 27th, 2017, 5:42 ] |
| Post subject: | Monolith SD Card Sandisk - > 8 Bit Or 16 Bit Pinout Wiring |
Hello To all My Seniors , I wanted to ask you that if i have a 16 Bit pinout SD Card From Sandisk And its Wired for 8 Bit Can it still Read Its ID Properly ? . I have one more question but i will ask after i get a reply to this one .I have a Sandisk Extreme 32 GB SD Card That is Iding Like 0x98009082 72570904 and i cannot pass Read ID section in PC3K .TS Guys Says ID is Not Correct ,I have Wired For SDHC Type 4 8 Bit pinout for this Sandisk .I checked all my connections are ok ,Micro Switch 1,2,3,4,5 are off and 6 is on .I2 that is WP is not connected .Also i have used VCC and GND from main pins and i have connected nothing to F1 and J1 VCC and K1 GND as i feel vcc and gnd can travel to that pins from main points of sd card .Shall i try and connect these three points . |
| Author: | arvika [ October 27th, 2017, 7:20 ] |
| Post subject: | Re: Monolith SD Card Sandisk - > 8 Bit Or 16 Bit Pinout Wiri |
Try on other reader to verify. It is typical problem with incorrect ID for monolith on PC3K reader. But it can be also some internal problem with chip or soldering. |
| Author: | Amarbir[CDR-Labs] [ October 27th, 2017, 7:37 ] |
arvika wrote: Try on other reader to verify. It is typical problem with incorrect ID for monolith on PC3K reader. But it can be also some internal problem with chip or soldering. This is The Problem Arvika Sir I have a single Horse Called PC3K Flash .Good Thing Would Be To Get The Hardware Part of Softcenter At Least As Soon As i Can Afford ,But in anycase Can You suggest How And what i Can Try |
| Author: | HaQue [ October 27th, 2017, 17:30 ] |
buy a SC reader :-0 |
| Author: | pcimage [ October 27th, 2017, 18:07 ] |
HaQue wrote: buy a SC reader :-0 Yeah, it’s cheap and good! Not fancy, but it works. Don’t forget to add the appropriate adaptors and the new voltage board! |
| Author: | Amarbir[CDR-Labs] [ October 28th, 2017, 6:51 ] |
pcimage wrote: HaQue wrote: buy a SC reader :-0 Yeah, it’s cheap and good! Not fancy, but it works. Don’t forget to add the appropriate adaptors and the new voltage board! Sean Sir , I will skip the power adapter i plan to make one in different design myself |
