 Post subject: Decrypt Android SD card
PostPosted: November 12th, 2017, 13:01
Hi Guys
I received a SD card from a client that was used on a android phone.
For what I can tell, the card have 2 partitions: android_meta and android_expand and this seems to be the result of encryption by Android OS.
I have checked this: http://nelenkov.blogspot.pt/2015/06/dec ... orage.html
But I was wondering if there's some kind of software/tool that can already manage this,
ACELab partner
 Post subject: Re: Decrypt Android SD card
PostPosted: November 12th, 2017, 16:07
What are Android version and phone from which card was removed ?
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: November 12th, 2017, 18:56
I don't have that info.
I will try to get it.
ACELab partner
PostPosted: November 15th, 2017, 13:44
Hi
Finally I have the specs:
The phone is a Primux Delta 6 https://www.primux.es/catalogo/nuevos/s ... elta-6/289 working with Android 6.0.
Any hints??
ACELab partner
PostPosted: November 16th, 2017, 4:02
@ pclab,
MicroSD Encryption inside Android OS.
the Basics, Encryption means KEY (should be somewhere to decrypt)
Android saves the KEY somewhere (hidden partition) and ONCE you format/restore Android Default its GONE
coz it will generate another one .. thats the point of Encryption.
you may start from here
Note: same concept when you FORMAT smartware drive using Its own format tool, it will Generate another KEY and whatever WAS THERE is gone. (UNLESS..!!!)
so far i don`t know any solution for such a case if the phone is formatted/restored. (unless someone correct this)
good luck
PostPosted: November 16th, 2017, 10:01
Thank you Einstein
ACELab partner
PostPosted: November 16th, 2017, 11:12
pclab wrote:
Hi Guys
I have indeed read all comments Below ,I wanted to ask something thats missing from post No 1 ,That is what are you trying to recover from this photos videos audio ?
PostPosted: November 16th, 2017, 11:47
@ pclab
You welcome ... :wink:
Users browsing this forum: Majestic-12 [Bot] and 40 guests
