 Post subject: OCZ Vertex SSD (Indilinx Barefoot 3) not recognized in BIOS
PostPosted: December 11th, 2017, 14:13
I have an OCZ Vertex 256GB SSD (Model VTR1-25SAT3-256G) with an Indilinx Barefoot 3 controller which suddenly stopped being recognized in the BIOS (of any computer).
As I understand it, this should be an easy problem to fix by using PC-3000 (with an SSD addon?) to fix the firmware using this tutorial: https://www.youtube.com/watch?v=Wxrg_helKLE
I'm wondering if there's any other options to fix the firmware. I'm in Canada and PC-3000 is very expensive considering I'd only be purchasing it to fix one drive.
 Post subject: Re: OCZ Vertex SSD (Indilinx Barefoot 3) not recognized in B
PostPosted: December 11th, 2017, 14:48
Why don’t you just take/send it to someone who has the kit and knows how to use it?
Recovery Force for example, they’re in Canada.
PostPosted: December 11th, 2017, 15:00
Start by measuring the onboard voltages. Next, check whether the SSD can communicate in "safe mode" or diagnostic mode, or whatever is applicable for this controller.
I could help you with the voltage test points if you could provide detailed photos of the PCB.
PostPosted: December 11th, 2017, 15:53
I'd first like to attempt to do this myself, I do find this type of thing interesting. Recovery Force is actually just a short drive away so I may end up resorting to that, but we'll see.
PostPosted: December 11th, 2017, 16:17
I don't currently have a working multi meter but yes, shorting the 2 pins at J3 gets it into technological mode (it shows up as BAREFOOT3-FACTORY-ROM).
Please see attached for the PCB pics.
PostPosted: December 11th, 2017, 16:33
The power supplies are located at the bottom left corner of "VertexBack.jpg". Given that you are getting the "BAREFOOT3" ID, the voltages are probably OK. In any case your photos are too poor to work with.
PostPosted: December 11th, 2017, 17:02
I replied to your message first but it hasn't shown up yet so I'll post it again:
PostPosted: December 11th, 2017, 17:04
Thank you for your help, sorry about the image quality, here's 3 more attempts at that area. I have managed to acquire a very cheap multimeter for testing.
PostPosted: December 11th, 2017, 17:55
Can you measure voltages V1, V2, V3 and pins 1,2,3 of U19?
Can you confirm whether the marking code on U19 is "JB-"?
Can you provide the markings on the "3x buck regulators" IC?
PostPosted: December 13th, 2017, 13:51
V1 is 3.010V
V2 is 1.000V
V3 is 1.519V
U19 Pin 1 is 0.000V
U19 Pin 2 is 5.087V
U19 Pin 3 is 2.528V
U19 Marking:
J B-
EA520
3x Buck Regulators IC Marking:
TPS
652510
T1 271G2
AZC6
PostPosted: December 13th, 2017, 16:24
Those voltages are OK.
References:
TPS652510, Texas Instruments, 4.5V to 16V Input, High Current 3A/2A, Synchronous Stepdown 3 DC-DC Converters With Integrated FET:
http://www.ti.com/lit/ds/symlink/tps652510.pdf
RT9166-25PXL, Richtek, 2.5V, 300mA Ultra-Fast Transient Response LDO regulator, marking JB-, SOT-89:
https://www.richtek.com/assets/product_file/RT9166=RT9166A/DS9166A-24.pdf
http://www.s-manuals.com/pdf/datasheet/r/t/rt9166%2C_rt9166a_richtek.pdf
Richtek marking information:
http://www.sacpower.net/uploadfiles/200781814055738.pdf
PostPosted: December 13th, 2017, 17:44
@OP..
With respect, you do realise that the PC3000 SSD “firmware fix” (as you call it) is no such thing?
It’s only a temporary “workaround” to gain access to the data in “safe mode” via a software built translator and data access via Data Extractor through the Indilinx utility in PC3K SSD.
This requires time-consuming imaging (a software translator is many many times slower than the inbuilt translator in the SSD) thus tying up both pc3k flash and a data Extractor channel for a considerable length of time.
PostPosted: December 13th, 2017, 18:29
I did not realize that, I thought the translator could be written back to the drive so I could attempt to boot from it (even if it was super slow). The drive has TrueCrypt full disk system encryption so files wouldn't be available in the Data Extractor. Just imaging to another drive may not work because I actually did have a full disk dd image backup of the drive but I found that restoring that image to another drive resulted in an unbootable system disk with most files missing/damaged... which may be because there's 2 bad sectors which I had dd skip over. The drive was working without problems though despite the bad sectors before and after the backup was taken.
Does this still sound like a scenario that PC-3000 can fix?
PostPosted: December 14th, 2017, 2:51
PC3000 DE can handle Truecrypt decryption "on the fly" with the password.
Have you tried mounting your clone with Truecrypt drive mounter from a working system, rather than trying to boot from it? Very odd that just two bad sectors should cause so many issues!
PostPosted: December 14th, 2017, 4:16
Depends of Your DDI setings there is posibility that 1-st sector is modyfied.
Mount this image with True Crypt to a working system and than use R-Studio or software like this.
Backup is Your best friend. Still learning English. Sorry for language bugs. My websites: Centrum Odzyskiwania Danych
PostPosted: December 14th, 2017, 10:59
Good to know PC-3000 can decrypt TrueCrypt partitions!
If I attempt to boot from the clone, I see the TrueCrypt bootloader and when I enter the correct password a Windows loading screen is shown where it says things like "Attempting repairs...", and eventually goes into a recovery mode where I attempt to access C: in the command prompt but it says it can't access it because the disk is RAW.
If I attempt to mount the clone using VeraCrypt (TrueCrypt compatible) on a working machine using the "Mount Without Pre-Boot Authentication..." option, the drive will mount but it gives a warning about an unclean filesystem and offers to run chkdsk. chkdsk then takes 5 hours, moves many things to a found.000 folder, and the drive capacity shows as 52GB used when the drive should have about 230GB used. None of the important files are available in this 52GB.
PostPosted: December 14th, 2017, 14:37
Make a new clone and do NOT run checkdisk
http://www.rescue-it.se
PostPosted: December 14th, 2017, 19:06
When I do this, the correct amount of disk space used is shown, but I'm unable to navigate to many of the directories due to the error:
[Folder Name] is not accessible.
The file or directory is corrupted and unreadable.
PostPosted: December 14th, 2017, 19:20
Try with RStudio for example
PostPosted: December 14th, 2017, 20:18
A scan with R-Studio 8 only finds about 63GB but none of the important files are available.
Users browsing this forum: No registered users and 42 guests
