| TLGA BGA And VBGA ChipOn -> Flash-Extractor Reader ? http://forum.hddguru.com/viewtopic.php?f=10&t=36234 |
Page 1 of 1 |
| Author: | Amarbir[CDR-Labs] [ December 26th, 2017, 0:29 ] |
| Post subject: | TLGA BGA And VBGA ChipOn -> Flash-Extractor Reader ? |
Hello, I wanted to ask the guys who have it .Do you need to reball The TLGA , BGA And VBGA Chips After You Remove From Defective Media Or these Adapters Read These Chips Without The Balls .If They Read Properly Only With The Balls That Means a Additional Step in Prep of Case . |
| Author: | arvika [ December 26th, 2017, 9:19 ] |
| Post subject: | Re: TLGA BGA And VBGA ChipOn -> Flash-Extractor Reader ? |
No need. |
| Author: | Amarbir[CDR-Labs] [ December 26th, 2017, 13:43 ] |
arvika wrote: No need. Hi, Thank You For Confirming Me This ,This Video Prompted Me to ask This Question -> https://www.youtube.com/watch?v=EjzG6HDh08E . PS : Jermy If you are seeing this i have left a few comments in some of the videos you made ,Can you reply to them . |
| Author: | Blizzard [ December 26th, 2017, 14:00 ] |
Hi Amarbir, reball is just needed if you move NAND to a donor device. As you know, you can not always get 100% by reading chip and reconstructing. We typically read/reconstruct data after removal, if it's not perfect then we check to see if we have a matching donor. If we have one then we reball and read 100%. |
| Author: | Amarbir[CDR-Labs] [ December 27th, 2017, 0:18 ] |
Blizzard wrote: Hi Amarbir, reball is just needed if you move NAND to a donor device. As you know, you can not always get 100% by reading chip and reconstructing. We typically read/reconstruct data after removal, if it's not perfect then we check to see if we have a matching donor. If we have one then we reball and read 100%. Thanks David , I would be placing order for my next second tool after pc3k flash tool first week jan 2018 |
