Duplicate SSD to USB
http://forum.hddguru.com/viewtopic.php?f=10&t=36346
Author:  rwtrader [ January 24th, 2018, 11:53 ]
Post subject:  Duplicate SSD to USB
I am using Raw Copy to duplicate an SSD system to a USB with the intent to remove SSD and boot Win10 from USB. I have tried several times with no success. Going from 120G to 128G. Files look like they are there, but will not boot. Bios changed to boot from USB.
I am sure it is something simple, but I'm at a loss... Thanks, Roy
Author:  dick [ January 24th, 2018, 13:44 ]
Post subject:  Re: Duplicate SSD to USB
Hi.
I think you are going to have to make an iso image of your ssd drive.
Then you have to use a tool like Rufus to prepare the usb device to boot and mount the windows 10 iso you created.
Take a look here: https://rufus.akeo.ie/
Author:  rwtrader [ January 24th, 2018, 13:55 ]
Thanks! I will give it a shot...
Author:  blackwolf511 [ January 24th, 2018, 18:26 ]
You cant make an hdd/ssd image copy to usb and boot from it. It doesn't work.
You can make a live cd, with nlite, but no boot from an image previously installed on hdd/ssd.
When the drivers will be loading it will give bsod (blues screen and reboot).
Try to install a fresh OS to usb and see if it's ok. (You should use a fast usb 3.0 or 3.1)
