Could you measure +3.3Vin and +3.3Vout at "C76"? This component looks like a P-channel MOSFET or high-side load switch.
Could you measure V1, V2, VLDO1, VLDO2, and VLDO3 at TPS650532?
Could you identify the markings on IC4 and IC5? What is the voltage on the adjacent capacitor/inductor?
Could you identify what is in the unknown location between the flash controller and NAND?
Could you identify the markings on the two components near the edge connector? Do they test like diodes?
TPS650532, Texas Instruments, 5-Ch Power Management IC w/ 2 Step-Down Converters + 3 LDOs, Vin = 2.5V - 6V, 1A, VQFN-24:
http://www.ti.com/lit/ds/symlink/tps65053.pdfNT5CC128M16FP-DI, Nanya, DDR3L SDRAM, 2Gbit 128Mx16, 1.35V, 96-Pin TFBGA:
http://www.nanya.com/en/Product/3775/NT5CC128M16FP-DIIhttp://www.wasuntech.com/upload/2017-06 ... 3_5361.pdf
