Data Recovery on SSD - Where did I go wrong?
Posted: March 29th, 2018, 14:37
Hey all,
I recently read an article about data recovery and was backing up my phone's pics when I had the curious idea to test some data recovery. I basically failed at what I wanted to do and I'm happy this was just a test run. However, I'm sure I'll have to do this for real some time, and I want to find out what I did wrong:
To test recovering files, I copied two folders of pictures on my second laptop (that were already backed up on my main laptop) which were over 10GB in size on the desktop.
Then I deleted them ("perma deleted" as they were too large to go on recycle bin).
The laptop was left closed for 2 hours doing nothing before I went to try and restore the pictures:
These were the steps I took with the laptop in which the files were deleted:
1. Googled deleted data recovery
2. Found out about TOKIWA DataRecovery software which requires no install and is only 200kb size.
3. Downloaded software directly to laptop's same drive as deleted pictures (Mistake 1?)
4. Ran the scan on the drive - Twice the scan crashed at about 20% complete, no idea why.
5. Third scan I manually stopped the search at about 15% as I could see that enough of the pics that I deleted that day were there (based on name and modified date).
6. I selected and pressed to recover the pics that were the right date onto an external hard drive.
7. Once restored, the pics would not open. I also took the external drive with restored pics to another laptop and tried to open them but still nothing.
8. They would not open even though they were the correct size and file extension.
9. I read online that renaming/ changing file extension occasionally works so tried that. Also tried opening them with VLC player which I've had success in opening weird file extension pics before, and repairing images with repair programs but nothing worked.
10. I went back to the laptop with deleted files and installed Panda Recovery. Software found all the pics deleted but claimed they were overwritten and no preview available. All other pics and files that were found from previous periods were intact and previewed fine. Recovering the correct pics, again they could not be open.
11. Then I installed a few other recovery software and had similar results. Only the pics I deleted that day were not open-able when recovered/previewed.
12. Last software I tried was photoRec. With it I gave up at about 30% scan of the drive as it was taking forever. It recovered 16,000 images but I could not find a single one from the recently deleted ones. I didn't check all the files as there were so many but I'm pretty sure it did not recover them.
Some info on the Laptop in which the files were deleted:
Windows 10
Sandisk 256GB SSD: Had 100GB left and has never been or close to being full
Questions:
1) How bad is downloading small files prior to recovering? I understand overwriting makes most retail software struggle, but surely 200kb and a few Mbs of temporary browsing data can't overwrite 10+GB of pics?
2) I assume the first recovery software may have done some damage, but I had stopped the scan when it had only found about 20-30% of all the pics deleted and only attempted to recover some of those. Therefore even if it corrupted those files, the other pics found later should have been fine if that was the issue?
3) Why was it possible to recover so many old pictures and not a single one had a problem opening except the pics that I intended to restore?
4) Is there any way to still attempt to recover these photos without professional help? Just for completeness of the test.
5) If this was a real data recovery, what software / method / steps would you have taken to increase chance of restoring the data?
Many thanks all in advance for any tips
Windows 10
Questions:
