| Toshiba USB I/O error http://forum.hddguru.com/viewtopic.php?f=10&t=36690 |
Page 1 of 1 |
| Author: | speakerbox [ April 13th, 2018, 12:43 ] |
| Post subject: | Toshiba USB I/O error |
I have this error with this Toshiba Transmemory 16GB USB. VID:04B3 PID:3025 I have successfully flashed a Kingston that had the same error using Phison UPTool but that would only leave the drive "usable" erasing everything. The I/O refers to the controller, right? I could "just" do a chip-off recovery. |
| Author: | HaQue [ April 13th, 2018, 18:58 ] |
| Post subject: | Re: Toshiba USB I/O error |
yes for IO error, either fix PCB problems (resistor short/open or broken solder joints) or chip-off. |
| Author: | fzabkar [ April 13th, 2018, 19:13 ] |
Google tells me that VID:04B3 PID:3025 is an "IBM SK-8825 KeyBoard" or "CHICONY USB NetVista Full Width Keyboard". |
| Author: | speakerbox [ April 13th, 2018, 19:48 ] |
fzabkar wrote: Google tells me that VID:04B3 PID:3025 is an "IBM SK-8825 KeyBoard" or "CHICONY USB NetVista Full Width Keyboard". Don't search like that http://flashboot.ru/iflash/ |
| Author: | speakerbox [ April 13th, 2018, 20:07 ] |
fzabkar wrote: Google tells me that VID:04B3 PID:3025 is an "IBM SK-8825 KeyBoard" or "CHICONY USB NetVista Full Width Keyboard". Also you can use this: http://www.flashdrive-repair.com/2013/1 ... tware.html |
| Author: | fzabkar [ April 13th, 2018, 20:43 ] |
AFAICT, 0x04B3 is IBM's VID. Toshiba's VID is 0x0930. http://www.users.on.net/~fzabkar/USB_IDs/uvcview_vid_nam.txt http://usb.userbenchmark.com/SpeedTest/4802/TOSHIBA-TransMemory http://www.tomshardware.com/answers/id-2715491/toshiba-transmemory-8gb-formatting-problems.html https://github.com/brandonlw/Psychson/issues/14 https://www.webfoobar.com/node/24
| Author: | speakerbox [ April 14th, 2018, 15:40 ] |
Hmmm weird, that is what I got with ChipGenius!! |
| Author: | rogfanther [ April 14th, 2018, 15:50 ] |
As per Chipgenius instructions, disconnect all other things usb from your computer before running it. It probably is detecting your keyboard, or you really have a fake usb drive. |
| Author: | HaQue [ April 14th, 2018, 19:50 ] |
When controller goes bad, anything can be reported. regardless of what it is reporting, just read the chip. is it a monolith or what is the controller and chip? what did CG say the nand ID is? |
