| iPhone 3GS data recovery, does chip-off work? http://forum.hddguru.com/viewtopic.php?f=10&t=36783 |
Page 1 of 1 |
| Author: | speakerbox [ May 5th, 2018, 13:02 ] |
| Post subject: | iPhone 3GS data recovery, does chip-off work? |
Or does the device need to be repaired due to encryption? not sure when Apple started doing that. TIA |
| Author: | arvika [ May 5th, 2018, 16:36 ] |
| Post subject: | Re: iPhone 3GS data recovery, does chip-off work? |
i4 is crypted for sure. 3G not crypted, 3GS not crypted too (based on one case quite long time ago). |
| Author: | einstein9 [ May 6th, 2018, 5:00 ] |
arvika wrote: i4 is crypted for sure. 3G not crypted, 3GS not crypted too (based on one case quite long time ago). +10 Encryption started from 4S |
| Author: | Amarbir[CDR-Labs] [ May 6th, 2018, 11:20 ] |
speakerbox wrote: Or does the device need to be repaired due to encryption? not sure when Apple started doing that. TIA Hi, This Phone Model is Not Encrypted .Chip off work properly |
| Author: | ddrecovery [ May 31st, 2018, 11:44 ] |
I have had a 3GS in for recovery a while ago. We did a chip off and the data was encrypted. I think the 3GS is where they started testing encryption, so some are and some aren't encrypted. |
| Author: | HaQue [ December 4th, 2018, 7:48 ] |
arvika wrote: i4 is crypted for sure. 3G not crypted, 3GS not crypted too (based on one case quite long time ago). Hi Michal, do you remember what layout you used, or tool? Amarbir wrote: Hi, This Phone Model is Not Encrypted .Chip off work properly Are you speaking from experience, did you dump and recover? If so would you say which tool and give any details? I have a 3GS chip here. package: LGA52 marking: Micron 9VA18 Crystals: 4 x 4GB ID : 2c d7 94 3e Bus : 8 bit page : 3420 possibly could be software bad columns. Anyone done chip off on these? not convinced this is encrypted as entropy not all that high. |
| Author: | ddrecovery [ December 4th, 2018, 9:55 ] |
I have done a chip off on the 3GS and it was encrypted. FWIK, the 3 was not encrypted, the 3G is where they were testing encryption and the 3GS is was full encryption. However there may be variations to this. |
| Author: | HaQue [ December 4th, 2018, 19:21 ] |
Thanks for that, cheers |
