PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
http://forum.hddguru.com/viewtopic.php?f=10&t=36864
Author:  salmanumar007 [ May 24th, 2018, 8:26 ]
Post subject:  PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
This ssd has MACAFEE ENCRYPTION i did tray to PSID revert but wont work kindly help me to decryption of this drive.
Author:  scratchy [ May 24th, 2018, 18:33 ]
Post subject:  Re: PLZ GURUS SAMSUNG SSD 850 PRO MACAFEE ENCRYPTION
You will need the mcaffee decryption software, the code of the day and the decryption key.
Author:  salmanumar007 [ May 30th, 2018, 4:43 ]
well thx to reply but i dont have any code or decryption key is there any way to force decrypt the drive bcoz i dont need any data from it any solution ?
Author:  lcoughey [ May 30th, 2018, 6:10 ]
Just reformat the SSD if you don't care about the data and want to reuse it.
Author:  MindMergepk [ May 30th, 2018, 13:32 ]
we can probably help you if interested, we are based in Faisalabad.
Do let me know if you are interested ? @ 03006689939
Author:  MindMergepk [ May 30th, 2018, 13:34 ]
my bad, sorry if you dont need data why bother to decrypt it ? as mentioned by Luke just format it use it.
good luck
Author:  salmanumar007 [ June 2nd, 2018, 3:33 ]
Well its wont format until its decrypted thats why i am looking for solution i have try many tools bt still wont format...
Author:  salmanumar007 [ June 11th, 2018, 4:28 ]
THX
Every one for such a nice comment i have unlock the ssd and its work fine now my apology it was TCG OPAL security which i found in Samsung magician watever it was i will share how did i unlock this drive with (sedutil)https://github.com/Drive-Trust-Alliance/sedutil/wiki/PSID-Revert
here is the file http://www.mediafire.com/file/u638377asinna3c/RESCUE32.img.gz/file
which u can tansfer to usb drive with Disk Image Writer and follow the commands on website hope this will help others user.
Author:  salmanumar007 [ June 14th, 2018, 5:06 ]
Spildit wrote:
Thanks for sharing this info/solution !
Welcome and its good to hear a positive response from you Spildit as i seen many time you did cooperate with many user which explain u a good person i have seen many forums expert wont even reply your topic but Gurus are decent and special long live Spildit :P
