 Post subject: SM2254G Plextor
PostPosted: July 21st, 2019, 11:24
Hi Guys
I have this Plextor SSD that is well ID, but no access to UA (stays busy).
This controller is not supported yet by PC3K.
Does anyone have any kind of solution?
ACELab partner
 Post subject: Re: SM2254G Plextor
PostPosted: July 21st, 2019, 16:28
In-circuit recovery of SSDs with "weak" NAND:
http://www.hddoracle.com/viewtopic.php?f=106&t=2740
PostPosted: July 22nd, 2019, 3:33
And how to connect?
Did you ever make one work?
ACELab partner
PostPosted: July 22nd, 2019, 3:49
pclab wrote:
And how to connect?
It's all explained in my tutorial.
Otherwise, show us the other side of the PCB.
This question was also answered in my tutorial with reference to the following thread:
viewtopic.php?f=1&t=38346
digisupport wrote:
Adjusting supply voltage can help in some cases, not detected Lenovo SSS0l25089 I have had two cases and one intel Pro 2500 where adjusting internal supply made the drive start and clone successfully.
PostPosted: July 23rd, 2019, 3:24
Hi
After all the case was solved with PC3000 DE.
Thanks for the help!
ACELab partner
