HDD GURU FORUMS
http://forum.hddguru.com/
Looking for pinout for monolithic SD Card
http://forum.hddguru.com/viewtopic.php?f=10&t=37153
Page 1 of 1
Author:  Giroot [ July 25th, 2018, 1:16 ]
Post subject:  Looking for pinout for monolithic SD Card
Hi, does anyone have the pinout for this kind of chip?
The problem with the chip is that a lot of the files are corrupted when you plug in the SD Card and read it. The SD Card detects fine and shows the correct size.
I made two different images of the SD Card using winhex, one copied forwards, and one copied backwards.
I compared them, and there was different information on each image.
Hoping to get a pinout to read the NAND directly and build the image manually.
Author:  arvika [ July 25th, 2018, 2:42 ]
Post subject:  Re: Looking for pinout for monolithic SD Card
I do not see this pinout before. Must be developed.
Author:  jeremyb [ July 25th, 2018, 20:33 ]
If you want I can develop a pin-out for it if you send it our way, I'm in the USA
jeremy at recovermyflashdrive.com
http://www.phpbb.com/
