| LGA52 dump with a TSOP48 one? http://forum.hddguru.com/viewtopic.php?f=10&t=37332 |
Page 1 of 1 |
| Author: | speakerbox [ September 3rd, 2018, 12:03 ] |
| Post subject: | LGA52 dump with a TSOP48 one? |
Hi, I have this LGA52 chip that I need to recovery badly. However I cannot wait for new adapters to arrive. I have NAND flash reader from flash extractor with the TSOP48 adapter. I should be able to do some wiring to the reader without any adapter to get this sorted meanwhile. I am not sure how much of the wiring is needed.
| Author: | HaQue [ September 3rd, 2018, 20:03 ] |
| Post subject: | Re: LGA52 dump with a TSOP48 one? |
Hi, depending on how many crystals ("banks" in SC terms), could be using one or both sets of contacts (xxx-0 and xxx-1). you will need all data and control signals for both, wire up xxx-0 first and read, then change and wire up xxx-1. make sure you change dump filename / number number in NR, so you dont overwrite first dump with the second. you will need : dump 1: VccQ VssQ R/B0-0 /CE0-0 RE-0 CLE-0 /WE-0 ALE-0 DQ0-0 - DQ7-0 etc... then do all the xx-1 |
| Author: | pcimage [ September 4th, 2018, 2:35 ] |
Sure it's an LGA-52 chip you've got there and not and LGA-60? |
| Author: | speakerbox [ September 8th, 2018, 11:03 ] |
HaQue wrote: Hi, depending on how many crystals ("banks" in SC terms), could be using one or both sets of contacts (xxx-0 and xxx-1). you will need all data and control signals for both, wire up xxx-0 first and read, then change and wire up xxx-1. make sure you change dump filename / number number in NR, so you dont overwrite first dump with the second. you will need : dump 1: VccQ VssQ R/B0-0 /CE0-0 RE-0 CLE-0 /WE-0 ALE-0 DQ0-0 - DQ7-0 etc... then do all the xx-1 Nice! |
