| SandDisk Ultra II 480 GB SSD files can't be seen http://forum.hddguru.com/viewtopic.php?f=10&t=37340 |
Page 1 of 1 |
| Author: | KoNpHuSiuS [ September 5th, 2018, 5:17 ] |
| Post subject: | SandDisk Ultra II 480 GB SSD files can't be seen |
Hi, I was running Windows 10 on this drive and on the last bootup it had the black screen with the white circle. It wouldn't boot into windows and I tried to recreate the Windows boot files to no avail. I searched and followed the instructions on this page: https://triplescomputers.com/blog/casestudies/repair-a-corrupted-efiuefi-boot-sector-and-bcd/ Afterwards I saw all my files had gone on this drive. I used EaseUS Data Recovery Wizard and Stellar Phoenix Windows Data Recovery to scan for files and they found nothing. How can I recover my files? |
| Author: | hddguy [ September 17th, 2018, 6:06 ] |
| Post subject: | Re: SandDisk Ultra II 480 GB SSD files can't be seen |
Quote: exit diskpart, and then perform a chkdsk command Quote: DISKPART> format quick fs=fat32 Probably you lost data as a result of CHKDSK, Format or both. Data should still be recoverable, but depending on how much work CHKDSK did and any other actions you made, it may not be a perfect recovery. If software already found nothing, maybe it is time to get it looked at by a professional who will know best approach and software to use - if data is important that is. |
