| SSD Samsung Evo 840 password incorrect after system crash http://forum.hddguru.com/viewtopic.php?f=10&t=37521 |
Page 1 of 1 |
| Author: | m4xx [ October 11th, 2018, 7:47 ] |
| Post subject: | SSD Samsung Evo 840 password incorrect after system crash |
Hello, I will explain my problem and hope someone can help. Initial situation I have an Acer Aspire V 15 Nitro with Win 8.1 and 2 hard drives. mSATA Liteon SSD (256 GB) - operating system Samsung SSD 840 EVO 500GB - Data More than a year ago I set a password in the BIOS for both hard disks and the BIOS itself (the same for all three). When switching on I was asked for the passwords and after input, the hard disks were unlocked and the system started. My problem and how it happened. I have working for a while as always and around noon the system hung/crashed, windows not responding then I did a hard reset (pressed long the power key). After that I have restarted and as with every start, the passwords promt for the hard disks pops up. I could unlock the first hard disk, then entered the password for the second hard disk and I get "Incorrect Password" message. Since then I can't unlock the hard drive. It's been a week now and since then I can't unlock the hard drive and I've read and tried many things but without success. Summary Samsung Support I have contact the Samsung Support, that's the result. They claim that they didn't have something like this yet and just offer me to send the SSD to them and they delete it completely after that I can use it again. However, no option for me I need the data. The ATA security concept knows two different passwords, the user password and the master password. I got this back on the request of the master password: Quote: Unfortunately, we have no instruction on how the ATA security concept works. Please contact the motherboard manufacturer directly and ask how to unlock the hard drive. Unfortunately we don't have a special tool or master passwords. We can only unlock the SSD in our Repair Center. But according to this document there is such a password At point 5.2.1 SECURITY (page 11) the master password is mentioned. Quote: 5.2.1 SECURITY mode default setting The 840 PRO is shipped with master password set to 20h value (ASCII blanks) and the lock function disabled. The system manufacturer/dealer may set a new master password by using the SECURITY SET PASSWORD command, without enabling the lock function. However, the support did not react directly to the document. My attempts to unlock the SSD with hdparm Information about the SSD: Code: ubuntu@ubuntu:~$ sudo hdparm -I /dev/sdb /dev/sdb: ATA device, with non-removable media Model Number: Samsung SSD 840 EVO 500GB Serial Number: S1DHNSAD903633N Firmware Revision: EXT0BB6Q Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0 Standards: Used: unknown (minor revision code 0x0039) Supported: 9 8 7 6 5 Likely used: 9 Configuration: Logical max current cylinders 130 130 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 131040 LBA user addressable sectors: 268435455 LBA48 user addressable sectors: 976773168 Logical Sector size: 512 bytes Physical Sector size: 512 bytes Logical Sector-0 offset: 0 bytes device size with M = 1024*1024: 476940 MBytes device size with M = 1000*1000: 500107 MBytes (500 GB) cache/buffer size = unknown Nominal Media Rotation Rate: Solid State Device Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, no device specific minimum R/W multiple sector transfer: Max = 1 Current = 1 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set * Security Mode feature set * Power Management feature set * Write cache * Look-ahead * Host Protected Area feature set * WRITE_BUFFER command * READ_BUFFER command * NOP cmd * DOWNLOAD_MICROCODE SET_MAX security extension * 48-bit Address feature set * Device Configuration Overlay feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART error logging * SMART self-test * General Purpose Logging feature set * WRITE_{DMA|MULTIPLE}_FUA_EXT * 64-bit World wide name Write-Read-Verify feature set * WRITE_UNCORRECTABLE_EXT command * {READ,WRITE}_DMA_EXT_GPL commands * Segmented DOWNLOAD_MICROCODE * Gen1 signaling speed (1.5Gb/s) * Gen2 signaling speed (3.0Gb/s) * Gen3 signaling speed (6.0Gb/s) * Native Command Queueing (NCQ) * Phy event counters * READ_LOG_DMA_EXT equivalent to READ_LOG_EXT DMA Setup Auto-Activate optimization Device-initiated interface power management * Asynchronous notification (eg. media change) * Software settings preservation * SMART Command Transport (SCT) feature set * SCT Write Same (AC2) * SCT Error Recovery Control (AC3) * SCT Features Control (AC4) * SCT Data Tables (AC5) * reserved 69[4] * DOWNLOAD MICROCODE DMA command * SET MAX SETPASSWORD/UNLOCK DMA commands * WRITE BUFFER DMA command * READ BUFFER DMA command * Data Set Management TRIM supported (limit 8 blocks) Security: Master password revision code = 65534 supported enabled locked not frozen not expired: security count supported: enhanced erase Security level high 2min for SECURITY ERASE UNIT. 8min for ENHANCED SECURITY ERASE UNIT. Logical Unit WWN Device Identifier: 50025388a0031dde NAA : 5 IEEE OUI : 002538 Unique ID : 8a0031dde Checksum: correct I have tried all security-unlock and disable commands with and without --user-master m, and pass the password also as scancode. Code: sudo hdparm --security-unlock $(printf '\x12\x12\x12\x12\x12\x12') /dev/sdb Anything without success, always get SG_IO: bad/missing sense data Code: ubuntu@ubuntu:~$ sudo hdparm --security-unlock "password" /dev/sdb security_password: "password" /dev/sdb: Issuing SECURITY_UNLOCK command, password="password", user=user SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 04 51 40 01 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 This is what I found about the code Code: 70 response code=Current information (about the error etc.) 00 05 sense code=Illegal Request 00 00 00 00 (not valid) 0a additional 10 bytes 04 51 40 01 (command specific) 21 04 additional sense code=Unaligned Write Command 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Master passwords I found and tested in every possible length from 1 - 32 characters and also as ScanCode:
Since the security level of the SSD is set to "high" it means that you can unlock the hard disk with the master password without losing the data and according to the master password revision code = 65534 the master password has not been changed and should still have the default value. I also built the Samsung SSD into an identical notebook and a computer all without success. The university of texas has published an interesting article Breaking ATA Password Security, they could remove the ATA Password with A-FF Repair Station but I can not try the software because the website is offline, via the web archive I could download the software but you need a login and this can not be created. Samsung Magician Status ![]() S.M.A.R.T ![]() I hope one of you can help me to unlock the SSD. |
| Author: | COD [ October 11th, 2018, 17:23 ] |
| Post subject: | Re: SSD Samsung Evo 840 password incorrect after system cras |
I think you need support from someone with pc3k. |
| Author: | m4xx [ October 29th, 2018, 13:50 ] |
Hello, is here someone from Germany with PC-3000 SSD, an want to help me ? Please send me a PN. |
| Author: | scratchy [ October 29th, 2018, 18:44 ] |
You hdparm should contain a reference to the password (user or master) hdparm —user-master u —security-unlock “password” /dev/sdx The u can be m for master or u for user sdx where x is the drive you want to unlock |
| Author: | scratchy [ October 29th, 2018, 18:50 ] |
Oh, and be careful when messing about with master password, is safest to use user pw. Try on an old drive by setting a password, unlocking and if ok, then disable with —security-disable replacing —security-unlock above |
| Author: | fzabkar [ October 30th, 2018, 3:11 ] |
Could this be something to try?
Remove the Liteon SSD and install the Samsung SSD in its place using an appropriate adapter. Now try to unlock it. |
| Author: | m4xx [ October 30th, 2018, 12:04 ] |
I have already tried hdparm with user-master u or m but I always get SG_IO: bad/missing sense data Code: /dev/sdb: Issuing SECURITY_UNLOCK command, password="password", user=user SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 04 51 40 01 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 The first thing I have done after the password problem from the Samsung SSD was to disable the password form my first drive (Liteon SSD). Quote: Remove the Liteon SSD and install the Samsung SSD in its place using an appropriate adapter. I don't thing that the interface has problems because my old hhd works. |
| Author: | fzabkar [ October 30th, 2018, 15:04 ] |
I didn't mean to suggest that there was something wrong with the interface. I was thinking that something may have changed in the NVRAM or CMOS RAM on the motherboard rather than the drive itself. FWIW, this is how Lenovo hashes the HDD/BIOS password: https://ascnb1.ru/forma1/download/file.php?id=25795&sid=c7a70e22e4647b212efb9190c1c6c1da http://notebook1.ru/forma1/viewtopic.php?f=52&t=84276 In your case you could try setting a password on a WD Scorpio drive and then dump the firmware to see what your Acer BIOS does with it. |
| Author: | sourcerer [ November 15th, 2018, 18:20 ] |
This paper might help with this case: https://www.ru.nl/publish/pages/909275/ ... aper_1.pdf |
