 Post subject: DR off a Compact Flash with AND Memory chips.
PostPosted: October 30th, 2018, 19:03
I have a Compact Flash card with markings:
Chip:
HN29W25611T-50H
Controller:
HN29W256SH02
The CF was able to be detected by the computer, but extracting any data was impossibly slow.
I found a datasheet for this chip:
https://www.digchip.com/datasheets/down ... 25611T-50H
What does AND type Flash Memory mean?
According to the datasheet, the pinouts for this chip are not the standard configuration for TSOP48, most likely because it was made before ONFI specifications.
Is chipoff recovery possible?
Would I need to purchase a different reader than FE, or ACELab? Or would I be able to connect the pin connections to the proper locations to read it normally?
Thanks!
 Post subject: Re: DR off a Compact Flash with AND Memory chips.
PostPosted: October 30th, 2018, 19:50
Have you tried warming or cooling the chip?
If there is a 3.3V LDO regulator, perhaps you could tweak the output voltage? I could possibly help with that.
PostPosted: October 31st, 2018, 14:33
Hi, thanks for your reply.
I tried warming and cooling the chip, no success.
On the board, I do see ICs that appear to be LDOs, but the chips have already been removed from the board.
PostPosted: October 31st, 2018, 20:04
It's probably too late now, but here is a simple adjustable regulator circuit that can be built for less than US$5. It provides an output voltage range of 2.5V to 3.5V.
            LM1117-ADJ
              ____
  Vout       |    |  Vin (+5V)
  o-+--------|LDO |---o
    |        |____|
   .-.  R1     |
   | | 120R    | adj
    |   _V_    |
    '--|___|---+
        RV1   .-.
       100R   | |  R2
              | |  220R
              GND
Vreg = 1.25V for LM1117-ADJ
Vout = Vreg x (1 + R2 / (R1 + RV1))
    = +2.5V (min) / +2.87V (mid) / +3.54V (max)
Users browsing this forum: No registered users and 38 guests
