| SSD - power surge http://forum.hddguru.com/viewtopic.php?f=10&t=37709 |
Page 1 of 1 |
| Author: | tetti [ November 20th, 2018, 20:57 ] |
| Post subject: | SSD - power surge |
Hi, I had a power surge, and now the comuter can not load the OS from it, and there is no access to SSD I tried to connect it externally via USB and nothing shows up do I have to spend $$$ to get it fixed or can I do somthing by my self ? its a SP S60 120GB thanks to anyone who can give some advice |
| Author: | pclab [ November 21st, 2018, 4:37 ] |
| Post subject: | Re: SSD - power surge |
Probably the PCB got fried as well. I think a good and knowledge electronic guy can fix it for you. |
| Author: | tetti [ November 21st, 2018, 5:25 ] |
thanks for the reply I can not see or smell any sign of burn, does it mean anything ? |
| Author: | tetti [ November 21st, 2018, 5:45 ] |
I opened the case and I have connected to power while open there are 2 red LEDs on (the LEDs were not visible when the case was closed) |
| Author: | mr_spokk [ November 22nd, 2018, 5:16 ] |
Drive could been entered "panic mode" and the firmware benn corrupted. If data is critical take the drive to a data recovery Company near you. This one has a Marvell controller, so should be recoverable even for chip-off |
| Author: | tetti [ November 22nd, 2018, 8:00 ] |
thnaks @ mr_spoke fo repling Quote: Drive could been entered "panic mode" and the firmware benn corrupted. what I understand from that that something logically got corrupted ?! you think that something like that can happen from A power surge ? and it is not something phisically ? Quote: This one has a Marvell controller, so should be recoverable even for chip-off it has a PHISON controller tha anwer is still the same ? |
| Author: | HaQue [ November 22nd, 2018, 19:21 ] |
depends on what part number Phison it is. is it PS3108-S8 (Phison S8)? If so, yes should be recoverable easily by Chip off method. Quote: There is a professional review from Tweaktown that states that SP recently (12/2014) changed the internal controller from Sandforce to a Phison.
| Author: | tetti [ November 23rd, 2018, 1:15 ] |
it's PS3109-S9 1. the answer is still the same ? 2. must be using chip off method ? it's not electronic/electrical problem ? |
| Author: | fzabkar [ November 23rd, 2018, 1:31 ] |
PC-3000 SSD. Phison Utility: https://blog.acelaboratory.com/pc-3000-ssd-phison-utility.html Quote: Right now the list of supported models includes the following cpu modifications:
Phison PS3108-S8 (all modifications and all models); Phison PS3109-S9 (all modifications and all models); Phison PS3110-S10 (all modifications and all models); Toshiba TC58NC1000 (all modifications and all models); Phison PS3111-S11 (all modifications and all models); Kingston CP33238B (all modifications and all models); It doesn’t matter which manufacturer produced your SSD. If your model is based on PS3105, PS3108, PS3109, PS3110 or PS3111 it will be completely supported. I would locate a DR shop which can recover your data without chip-off. Chip-off should only be a last resort. |
| Author: | tetti [ November 23rd, 2018, 1:42 ] |
fzabkar wrote: I would locate a DR shop which can recover your data without chip-off. thanks for repling do you think it's an electronic/electrical problem ? |
| Author: | fzabkar [ November 23rd, 2018, 1:49 ] |
tetti wrote: do you think it's an electronic/electrical problem ? Probably not. |
| Author: | tetti [ November 23rd, 2018, 1:59 ] |
reading the artical from the link you'v provided fzabkar wrote: https://blog.acelaboratory.com/pc-3000-ssd-phison-utility.html
makes me think that mr_spoke might be right mr_spokk wrote: Drive could been entered "panic mode" and the firmware benn corrupted. |
| Author: | mr_spokk [ November 24th, 2018, 6:12 ] |
In the state the drive is in you should find a local data recovery company (near the Good Place you live in |
| Author: | arvika [ November 24th, 2018, 6:22 ] |
Better recover data via controller, result will be better than chip-off. Assembling algorithm for this controller is not perfect so chip-off could give little worse result. But sometimes it is only solution if working with FW is not possible. |
