 Post subject: TSOP 48W
PostPosted: December 19th, 2018, 12:28
I have a Sandisk TSOP 48W chip that ID's as 2C010203 which seems unusual.
The chip is: SDTNSGBMB - 32GB.
Anyone know the correct pin scheme for this chip?
 Post subject: Re: TSOP 48W
PostPosted: December 19th, 2018, 14:29
ID: 2C010203, check short Dx signal to GND.
PostPosted: December 19th, 2018, 14:40
If you mean Datalines (Dx), they all check out okay.
Also checked in diode mode and they all give c1450.
PostPosted: December 19th, 2018, 14:49
Yes, from my notes: I receive similar ID when some D was shorted to GND.
PostPosted: December 19th, 2018, 14:53
Many thanks. I guess the chip has some internal damage.
PostPosted: December 23rd, 2018, 13:56
Chip is internally damaged..
Error code for when the internal NAND controller works but the internal NAND is damaged, usually by overvoltage.
Recover My Flash Drive
PostPosted: December 23rd, 2018, 18:46
some of the wide tsop's are 1.8v core
PostPosted: December 23rd, 2018, 18:57
I ended up buying the Ace Labs TSOP 48W adapter but the chip wouldn't read.
Thanks for the help.
