| Ssd cloning help http://forum.hddguru.com/viewtopic.php?f=10&t=37941 |
Page 1 of 1 |
| Author: | ykohavix [ January 15th, 2019, 5:07 ] |
| Post subject: | Ssd cloning help |
Hello members, I have Lenovo yoga 2,13” with 128gb Ssd with win 8 on it, I bought whitelist compatible crucial 500 ssd to replace it. So in your experience what would be recommended method to clone them? What adapter should I use to do the job? Both Ssd are: sata3 / m.2 / NGFF / 80mm long. Any help I appreciate . |
| Author: | techie19 [ January 21st, 2019, 0:49 ] |
| Post subject: | Re: Ssd cloning help |
I’m in the process of updating my laptops HDD to an SSD. I found the following on Amazon: Sabrent USB 3.0 to SSD / 2.5-Inch SATA I/II/IIIHard Drive Adapter (EC-SSHD) https://www.amazon.com/dp/B011M8YACM/re ... rCbHAQMKP0 As far as cloning software, I’ve come across a few with very good reviews. Acronis True Image, MiniTool Partition Wizard, AOMEI Backupper, Macrium Reflect. |
| Author: | techie19 [ January 21st, 2019, 1:16 ] |
Sabrent USB 3.0 to SSD / 2.5-Inch SATA I/II/IIIHard Drive Adapter (EC-SSHD) https://www.amazon.com/dp/B011M8YACM/re ... rCbHAQMKP0 Some cloning software ideas are: MiniTool Partition Wizard, Macrium Reflect, Acronis True Image. |
| Author: | ykohavix [ January 21st, 2019, 8:35 ] |
techie19 Good luck with your cloning, Hence this is not related to m.2 SATA interface at all without another special adapter, Your link refer to regular SSD with 2.5-inch interface. |
| Author: | techie19 [ January 21st, 2019, 18:50 ] |
ykohavix wrote: techie19 Good luck with your cloning, Hence this is not related to m.2 SATA interface at all without another special adapter, Your link refer to regular SSD with 2.5-inch interface. Sorry I misread your post. |
