HDD GURU FORUMS
http://forum.hddguru.com/
TOSHIBA THNSNS128GCSP Empty sectors
http://forum.hddguru.com/viewtopic.php?f=10&t=38038
Page 1 of 1
Author:  Maestro [ February 7th, 2019, 11:59 ]
Post subject:  TOSHIBA THNSNS128GCSP Empty sectors
Hello everyone,
I have this Toshiba SSD drive that all sectors look empty. Does anyone know how to deal with this kind of problem on this drive?
Thanx everyone in adnvance.
Maestro
Author:  HaQue [ February 7th, 2019, 18:39 ]
Post subject:  Re: TOSHIBA THNSNS128GCSP Empty sectors
is there a possibility that it is actually true, and they are all empty?
Author:  pcimage [ February 8th, 2019, 2:05 ]
Did some wise guy try to “format and then recover the data” like we’ve heard a hundred times from people when trying to recover a hard drive?
Author:  Maestro [ February 8th, 2019, 4:02 ]
No i am sure that its not the "format and then recover data" type of case.
Its a problem from the SSD but unfortunately that controller is not supported by Acelab.
And i am trying to find if there is another way to recover data.
Thanx
Maestro
Author:  arvika [ February 8th, 2019, 4:12 ]
Please put photo here.
Author:  Maestro [ February 8th, 2019, 8:10 ]
Here are photos from the drive
Thank you
Maestro
Author:  HaQue [ February 8th, 2019, 9:09 ]
Being SandForce makes it hard. Contact Northwind. They are in Greece but are highly respected for DR. There are not many shops that have, but they do have some SandForce solutions.
Author:  arvika [ February 8th, 2019, 9:10 ]
It is Sandforce controller rebranded to Toshiba. Common problem.
Author:  Maestro [ February 8th, 2019, 10:53 ]
Thank you for your help.
Maestro.
Author:  pcimage [ February 9th, 2019, 14:50 ]
Maybe recoverable but not DIY.
If data is important then contact Northwind
Author:  northwind [ February 10th, 2019, 3:39 ]
Yep, we should be able to handle those.
http://www.phpbb.com/
