 Post subject: Seagate ST3000DM001 Weird Rom
PostPosted: March 29th, 2019, 13:53
Hi guys, I've been having some troubles with a drive and I was looking at the rom and found something strange (to me, as someone who isn't used to read roms)
Here are some screenshots, can someone confirm either this is normal or not?
http://imgur.com/a/ykFqe6M
http://imgur.com/a/7MFq5du
 Post subject: Re: Seagate ST3000DM001 Weird Rom
PostPosted: March 29th, 2019, 14:08
Looks normal to me :)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 30th, 2019, 4:25
what is the drive behavior on power up?
Data Recovery Pakistan
PostPosted: March 30th, 2019, 4:43
I've examined numerous ROMs and I do recall seeing those same text strings.
http://www.hddoracle.com/viewtopic.php?f=59&t=2173&p=14535&hilit=hrk#p14535
PostPosted: March 31st, 2019, 17:37
The drive powers up, clicks a bit and stops clicking, board gets really hot tho.
PostPosted: April 1st, 2019, 5:02
Those strings are present in a Granada ROM, nothing unusual there.
Personally i would take a look at the heads under microscope, will most likely tell you what you are dealing with. If none of the heads are dirty, maybe terminal can give you hint about whats going on.
Users browsing this forum: No registered users and 14 guests
cron
